Author Topic: CB750A Hondamatic sharp metallic clinking and clanking  (Read 6243 times)
Offline Medyo Bastos
  • Gusto mo titi ko?
    • project
Re: CB750A Hondamatic sharp metallic clinking and clanking
« Reply #25 on: September 21, 2021, 07:17:05 PM »
***Coan Engineering UPDATE*** got a call from Todd. He said they can for sure machine and get the stall speed up on the tc I sent in! I told him there is a handful other knuckleheads looking to do the same!
Offline kmb69
« Reply #26 on: September 22, 2021, 06:26:28 AM »
Awesome!
Many Thanks
« Reply #27 on: September 22, 2021, 11:38:13 AM »
That is awesome. I wonder if they would be able to approximate the stall by how much (and how) material is removed from the stator.
  • Gusto mo titi ko?
    • project
« Reply #28 on: September 22, 2021, 02:03:11 PM »
Just out of curiosity, what stall speed are you guys after?
« Reply #29 on: September 24, 2021, 04:30:37 PM »
 I noticed a few inexpensive converters on ebay in case anyone needs adjustment. I may save my A case for a while.
  • Gusto mo titi ko?
    • project
« Reply #30 on: September 24, 2021, 07:33:09 PM »
Looks like they can loosen up about 500 rpms without extensive machining.
« Reply #31 on: September 30, 2021, 04:36:38 PM »
 That's a good number. Cam accordingly. Fill us in on the details when you get it back.
« Last Edit: October 17, 2021, 11:35:35 PM by Don R »
Offline jukku
  • Happy with my Hondamatic
« Reply #32 on: June 22, 2022, 12:16:52 PM »
Hello
The third of my CB750A Tomatics started clinking and clanking. I´ll drive this summer with the "accompaniment" from the gearbox. It is a feature not a fault. ;-)
Have to find two of the gaskets that I´m missing.
The clutches tend to slip a bit when I hit the throttle, too much torque with with 836 10:25 Wisecos, K7 carbs, F2 cam advanced a bit?
  • Gusto mo titi ko?
    • project
« Reply #33 on: June 22, 2022, 02:21:53 PM »
Clutch parts are available; they are the same as the Honda cvcc
Offline newday777
« Reply #34 on: June 26, 2022, 04:06:24 AM »
Hello
The 836 shouldn't be the slipping problem as there have been many of the automatic 750s drag raced.
Exactly what oil do you have in it?
Stu
My current rides
Prior bikes....
Offline jukku
« Reply #35 on: June 30, 2022, 12:17:49 PM »
Gulf single 40 used in classic cars.
Temperature is now about 30 degrees celsius.
Offline jukku
« Reply #36 on: July 15, 2022, 11:13:10 AM »
The source of the CB750A Hondamatic sharp metallic clinking and clanking
http://forums.sohc4.net/index.php?action=dlattach;topic=99952.0;attach=411532
Page -6-
Fig. 5
Stopper Pin and Regulator Valve Drive Arm acts as "anvil and hammer".
It is not a fault, but a characteristic. ;-)
Offline TdLpps
« Reply #37 on: July 15, 2022, 01:25:26 PM »
Great document.  Thanks for attaching to the thread.
