Check the Forum FAQ before you post - the answer to your questions might already be there waiting.
Dave is correct about the cam's r2 marking indicating it is oem and it does not tell you anything about what year 750 it is from. It is possible that it is a re-grind though. Look for stamped markings, not cast in. Regrind stamps are usually found on the ends of the cam. 392 is part number code for 77/78k cb750's, iirc.
