Author Topic: Bearing question  (Read 1020 times)
Offline bert96
  • past ride
Bearing question
« on: July 15, 2021, 02:22:46 AM »
I'm rebuilding a  Honda cb77 1965. I try to buy a bearing for my transmission but I can't find it. Here what I can read on it: koyo 6206NS4.
I did some research but I can't find the meaning of NS4!?!
Someone can tell me where I could buy a new one,I would like to buy a good quality bearing !
Thank you
Bert
QA50 1969,ST-90 1974,mb5 1982,rz350 1983,shadow 1100 1985,vf1000f 1985,BMW K1 1990,shadow tourer 1100 2001,vfr 750 1994,vtr250 199?
Offline markmyodb
  • Honda owner since 1969. 19 Honda motorcyles, cars, and lawn mowers through the years!
  • Always looking for SOHC people to ride with in NC
Re: Bearing question
« Reply #1 on: July 15, 2021, 04:08:46 AM »
I rebuilt Machine tools 30 years ago, even then some of the older manufacturer's codes were not available to cross check. Generally I would select the correct size, the 6209 part, then select the current designation for retainer, or seals.  Bearing Clearance was always one of the hard calls things to determine, I learned that unless the bearing was subjected to high temperature differential between the inner or outer race, standard clearance was suitable. I would expect this to be true with transmission bearings.
With Transmission bearings one of the problems is the retaining ring groove, Honda seems to have had special bearings made.  a good machine shop with a quality lathe and ceramic tooling can cut them...Money
Modern bearings from quality bearing companies are generally better quality then bearings were then.  Better Steel, tighter manufacturing tolerances. I trusted SKF NSK, or KOYO.  (in the past I preferred Fafnir and other US manufactures. They have been bought up.)
Mark
I tell my wife the motorcycles are an investment...
CB550K1: 1975
CB750K6: 1976
Offline Mark K
« Reply #2 on: July 15, 2021, 11:07:29 AM »
Thank you
Bert
Bert,
I searched for the meaning of NS4 with no luck.
Maybe the 'NS' in NS4 is actually HS?
I did look at the CB77 Parts manual transmission parts diagram. It lists this information;
Ref #23, part # 91033-259-000, BEARING, ball, 6305HS
Found #23 at CMS - https://www.cmsnl.com/products/bearing-6305hs_91003259000/  - Euros 21.50 ~ Dollars $25.38
Ref #24, part # 91004-259-000, BEARING, ball, 6206HS
Found 91004-259-000 on eBay here - https://www.ebay.com/p/1311840437  - $52.58 + $5.99 shipping
CMS does not currently have availability of the 6206HS bearing.
Hope this helps,
Mark K.
« Last Edit: July 15, 2021, 11:15:14 AM by Mark K »
'13 Yamaha FJR1300, '73 Honda CB750K3 (current project), '19 Kawasaki KLX 140G, '72 Honda CL70K3, '70 Honda SL350 (next project)
Former bikes
'74 Yamaha 60, '72 Maico 250, '74 Kawasaki 250 S1, '82 Kawasaki KZ550, '84 Honda VF700F Interceptor, '99 HD FLSTS Heritage Springer, '97 HD FLHTCUI Ultra Classic '05 HD FLHT Electraglide, '9? Buell Lightning, '03 FLHTCUI Ultra Classic,'14 Honda CRF250L
Offline bert96
  • past ride
« Reply #3 on: July 15, 2021, 12:18:39 PM »
Thank you
Bert
Bert,
Hope this helps,
Mark K.
Yes i saw the one on Ebay,but i'm not sure if i trust the seller...
I've send an email to koyo. I'll wait their answer...
Envoyé de mon BBB100-1 en utilisant Tapatalk
Offline bert96
  • past ride
« Reply #4 on: July 15, 2021, 12:24:31 PM »
Mark,would go with a C3 or a C4?
Offline Mark K
« Reply #5 on: July 16, 2021, 12:02:27 PM »
Bert,
I do not understand, "C3 or C4"
What are you referring to?
Former bikes
Offline 69cb750
« Reply #6 on: July 16, 2021, 12:13:12 PM »
« Reply #7 on: July 16, 2021, 12:24:17 PM »
C3 and C4 refer to the bearing clearance or how loose the race to balls are in the bearing...
Offline bert96
  • past ride
« Reply #8 on: July 16, 2021, 12:40:50 PM »
Yep clearance.
