Author Topic: Oiling a dry engine  (Read 1682 times)
Offline grumburg
  • 74550, 76400F, 72 750 67S90, 68CL90, 65 s65 66 x6
Oiling a dry engine
« on: February 26, 2007, 05:17:53 PM »
Now that the 500T is about done, it is time to fire it up. S ince they do not have an oil pressure light, how long should I crank it before I hook up the fuel and try to start it?
Fonda Honda
Offline RRRToolSolutions
  • I love old Japanese bikes!
Re: Oiling a dry engine
« Reply #1 on: February 27, 2007, 04:30:24 AM »
I had hoped someone that knew these bikes would come on and give you some advice. If they don't have a port where you can screw-in a pressure gauge, you could alwasy pull one of the valve adjustment covers and watch for the oil to make it to the top. The rocker assemblies get quite a bit of oil, so it should not take long to see it moving up there.
Best of luck - Gordon
Kaws, Hondas, Yamahas, and Suzukis - especially Kaws
Offline Raul CB750K1
« Reply #2 on: February 27, 2007, 03:28:10 PM »
I gently oiled with clean oil and a brush all the parts while reasembling the engine (camshaft, rockers etc) so when the times come to start it I'm positive they will have enough oil until the pump start to do its work. Actually, there is no difference with starting a bike that has been sitting for a couple of weeks: the oil is below, in the pan, and the parts keep just a film of oil.
Offline Jonesy
  • Shop Rat
« Reply #3 on: February 27, 2007, 04:10:07 PM »
That's what I do as well. I also fill up any valleys with fresh oil (such as the in the head or sump) that would normally accumulate a quantity of oil, E.I. the troughs that hold oil for the cam lobes to dip into.
Offline chung
  • Giddy Up
    • chungfucycles.com
« Reply #4 on: February 27, 2007, 08:40:27 PM »
I opened a 450 pump. I don't think they have any oil pressure. LOL Seriously, it takes quite a long time to get oil to the head. 30 seconds at idle? Think I read that somewhere.
Member#2815
1971/76 CB750 Hack @970cc,
1975 CG750K
1970 CB350,
1972 YDS7, 250
1972 YR5, 350
1977 RD400,
1978 Piaggio Grande/Batavas HS50 Special
1981 XS650 Special II
