Author Topic: CB550 Seat Hardware - Bracket Dimensions?  (Read 1289 times)
Offline TPIGroove
« on: July 23, 2021, 12:39:46 AM »
Hello all. I'm slowly working my way through my 550, and it's just missing a lot of little bits here and there. It previously had a cruiser seat on it (which a previous owner apparently tossed without thinking) so the original seat seems to just be missing all sorts of bits. I've sourced most of the rubber, but my biggest hurdle is coughing up the $50 or so on ebay for the seat's hinge bracket. That seems a bit expensive for a hunk of metal, so I was thinking of just fabricating my own from some steel I have laying around. Would anybody mind taking pictures of theirs next to a ruler from a few angles?
Re: CB550 Seat Hardware - Bracket Dimensions?
« Reply #1 on: July 23, 2021, 06:37:26 AM »
Which model, F or K?  I may have a spare as I have a couple seats laying around...
Any other bits you may need?  I lost my storage and had to clean it out and have too many parts in my garage....
Offline TPIGroove
« Reply #2 on: July 23, 2021, 09:29:01 AM »
Whoops, I really should have specified, sorry! It's a '74 K0. I really want to keep this seat, it's been reupholstered with white and I love the way it looks. I also need to find the screws that hold the strap to the seat.
Offline Kelly E
  • Geriatric Hooligan
« Reply #3 on: July 23, 2021, 09:35:16 AM »
Here's a shot of the seat bottom and the hinge on my 74' 550K0
1978 Kawasaki KL 250
1980 Suzuki GS 1100E
1983 Honda CB 1100F
1984 Honda VF 700S Sabre
1990 Moto Guzzi 1000 Le Mans
2005 Harley Davidson Fat Boy
« Reply #4 on: July 23, 2021, 09:47:26 AM »
That one same as 500 except K0 500
Offline TPIGroove
« Reply #5 on: July 23, 2021, 10:09:10 AM »
I really need the dimensions of it so I can recreate it.
Offline Kevnz
« Reply #6 on: July 23, 2021, 08:16:30 PM »
120mm between inner faces, 25mm wide. 25 from bottom of base to hole centre, 10mm offset seat base holes to hinge holes.
Good grammar: The difference between knowing your #$%* and knowing you're #$%*
Offline TPIGroove
« Reply #7 on: July 23, 2021, 10:10:31 PM »
Thank you VERY much, this will certainly help me out. My biggest concern was getting the location of the hinge holes correct, I should be able to use this.
Offline Kevnz
« Reply #8 on: July 23, 2021, 10:47:13 PM »
Let me know if you need any more details.
