Author Topic: reconditioning of spark plug cables  (Read 1021 times)
Offline _mark
« on: July 26, 2021, 03:07:46 AM »
Hi . My spark plugs cables are hardened and aged and, due to this, one of them has lost the cap for the spark plug.
Is there a way to change/recondition them or only option is to change the coils ? thanks and regards.
Re: reconditioning of spark plug cables
« Reply #1 on: July 26, 2021, 03:14:39 AM »
Got to the uk site and look in alladins cave and a member there called ashimoto has done a detailed write up on repairing coils
Offline Deltarider
« Reply #2 on: July 26, 2021, 03:26:28 AM »
"hardened and aged" is not necessarily a cause for issues. Also, the problem is rarely where the cables exit the coils, even when you may think it feels flimsy. So I'd start by simply clipping the cable ends 1-2 mm and firmly screw on the plugcaps again. But not before you have used the occasion to check the resistances. Each plugcap should have 5-7 kΩ  and from one cable's end to the other you should have 13-15kΩ.
CB500K2-ED Excel black
Offline _mark
« Reply #3 on: July 26, 2021, 05:58:39 AM »
No problems. After dismantling the engine, one cable lost its spark plug cap. I tried to screw the cap inside but the cable is old and the thread worn. The cable is already short at its limit and cutting again may be I can't reach the spark plug.
Thanks.
Offline david 750f
  • 1976 CB750F
« Reply #4 on: July 26, 2021, 08:42:56 AM »
If your plug wire is too short you can use a plug wire splicer. That’s the cheapest fix. ($5-10)
https://4into1.com/ngk-spark-plug-ignition-coil-cable-splicer/
1976 CB 750F
Offline Bodi
« Reply #5 on: July 26, 2021, 08:48:07 AM »
The splicer is a good deal. Use metal core replacement cable.
If you want to spend a few Euros you can get Dyna replacement coils - these mount to the stock brackets with a bit of filing - and the Dyna cable kit. The cable ends attach with automotive type distributor plugs and you cut the cable to length (each comes with connectors on both ends of a pretty long cable piece).
Offline Little_Phil
« Reply #6 on: July 26, 2021, 10:31:31 AM »
I've done two sets like that. It does involve removing some of the potting around the cable where it enters the coils, a bit of soldering and repotting. But pretty simple and bingo brand new HT leads.
Offline middletons
« Reply #7 on: July 27, 2021, 08:51:59 AM »
as above, I just got done doing the same on my 550F. not real pretty looking, but works great!
« Reply #8 on: July 27, 2021, 11:29:02 AM »
Has Anyone tried the wintergreen oil trick on these ignition leads?
If not, I might give it a go.
