Author Topic: Stop light 1976 550 F  (Read 435 times)
Offline Tancdoc
« on: August 05, 2021, 01:38:15 PM »
Hello,
My stop light does not work when I actuate either the front or the rear brake. The tail light works fine. I thought it was a bulb problem, so I changed it to a new one but no difference. Where to look next to solve the problem? Interesting enough I have the same problem on my 1975 400 Super Sport.
May it be infectious :)
Thanks for the advice.
Offline calj737
  • I refuse...
Re: Stop light 1976 550 F
« Reply #1 on: August 05, 2021, 02:37:15 PM »
Should be a green wire with yellow stripe feeding the brake light circuit. Confirm that when that wire gets grounded, the brake light comes on (tail light).
« Reply #2 on: August 05, 2021, 04:30:38 PM »
Go to switch near kickstart and follow switch wires into rubber boot, black should have +ve 12v with ignition on and if so and you connect black and yellow/green light should work
Offline Greyhound
« Reply #3 on: August 05, 2021, 05:50:42 PM »
Additionally, you can grab a multimeter and check to see if you’re getting power at the brake light wire when you actuate the brake pedal/switch (this will eliminate the possibility of a bad socket and/or if the bulb is bad/incorrect).
If you don’t power at the brake light, then start working your way back along the wire, checking every connection until you find where you finally get a hot wire.
« Last Edit: August 05, 2021, 11:13:34 PM by Greyhound »
1977 CB550K3
Offline Robbo
« Reply #4 on: August 05, 2021, 06:29:56 PM »
You are using the correct dual filament bulb…???
1973 CB350 Four, 1975 CB550K
