Author Topic: Cb360 carb rebuild kit  (Read 866 times)
Offline samm_j2
« on: August 09, 2021, 12:55:24 PM »
I am helping a friend rebuild a cb360, does anyone know where to get a GOOD carb rebuild kit?
Thanks
Offline samm_j2
Re: Cb360 carb rebuild kit
« Reply #1 on: August 09, 2021, 01:32:50 PM »
Year is a 74, I know some are good and some are bad so any info would be great.
Yhanks
« Reply #2 on: August 09, 2021, 04:03:15 PM »
Don't buy a damn thing until you confirm the CV diaphragms does not have hole because if they do you might as well start looking at Mikuni VM's.
Offline samm_j2
« Reply #3 on: August 09, 2021, 04:59:41 PM »
Thanks Sean,
the slides were stuck and an absolute nightmare to remove. We finally got em out. I diaphragms looked good to me, no larg tears or anything. Is there a Way to test em??
« Reply #4 on: August 09, 2021, 05:51:32 PM »
 You basically need to hold them in your fingers gently and carefully look for any tears or pinholes and feelhow pliable the rubber is.
Offline samm_j2
« Reply #5 on: August 09, 2021, 08:44:50 PM »
Well... looks like we need new diaphragms... or new carbs. Seems like replacing the diaphragms is a pain. Gonna try these jbm unless someone has another suggestion.
Thanks
Offline middletons
« Reply #6 on: August 12, 2021, 07:27:50 AM »
yep, JBM industries is really the only source i've found. folks have had mixed results with them though. I've used then on one set of carbs and they seemed fine, but i didn't have that bike for very long. search over at Do The Ton or Vintage Honda Twins for more info.
