Author Topic: Frame year different than title  (Read 3285 times)
Offline Mticar1
« on: August 18, 2021, 11:36:44 AM »
I was reading how some of the early CB750s have early frames with later model years, ie. a k2 frame number with a title that says its a 1973.  I have a 1973, so I checked it, my frame number is CB750-1009821, the engine number plate is blank, but after some research I believe I have an early K3 motor, with the "extra" fin supports.  When I look up the frame number it comes up as 1969/1970, but I'm not sure because everything I found has the starting frame number but not the end of run frame number. And like I said the title says 1973 and the vin matches the title, is it possible it's K1 or K0 frame?  Does it make a difference?  Should I be concerned?
Thank you for any help
Re: Frame year different than title
« Reply #1 on: August 18, 2021, 12:08:58 PM »
 In some areas the bike was titled the year it was sold, one possibility. American Honda often sent new titles for previous year bikes. The blank engine plate is on a replacement case.
Offline jlh3rd
  • "just who gets to determine my needs?
« Reply #2 on: August 18, 2021, 12:16:37 PM »
so, a common misconception concerning honda, especially with new people is that honda always designated model years. Not true. That didn't start officially until 1974. Prior to that , it was a model number with a sell/release date.
    Hence the confusion sometimes with a title, as some places made the date a bike was sold as the "model" year. You could see this happening with left over or late release date bikes.
     Your frame is a CB 750KO , released 06/06/69....very important.
If the engine vin plate is blank, then that is a replacement case that appears to have not been dealer stamped. All Honda replacement cases were unstamped from the factory.
      Yes, it's very important in your case, value wise. It would be of interest for you to see what that engine is.
Lots of 750 experts on here.
« Last Edit: August 18, 2021, 12:22:56 PM by jlh3rd »
"alleged greed is usually a lazy person's opinion"
Offline jlh3rd
« Reply #3 on: August 18, 2021, 12:23:47 PM »
what color is the bike...pics?....many early model 750's had engine cases replaced due to chain breakage which knocked a hole in the case........so...very curious...
and, the first 750's sold weren't even known as KO's...just CB750.....honda added that in hindsight....
I think sandcast experts are needed here.
« Last Edit: August 18, 2021, 12:34:46 PM by jlh3rd »
« Reply #4 on: August 18, 2021, 12:42:02 PM »
Yes, sounds like you have a K0 frame and the motor was a replacement, possibly from a broken chain that cracked the case in the front sprocket area, fairly common.  If the dealer replaced the motor, they were to resamp the replacement motor, obviously that did not happen in your case, also fairly common.
What is the condition of the bike? With a matching motor, you would have a very valuable bike. Your bike came with a "Sandcast" motor, there were only 7414 made, then they switched to diecast for the rest of the run.  Here is a good explanation...
https://www.hagerty.com/media/motorcycles/why-do-collectors-pay-double-for-a-honda-cb750-engine-cast-in-sand/
Offline Mticar1
« Reply #5 on: August 18, 2021, 01:11:42 PM »
I'm pretty sure its a k3 motor.  The bike was pretty beat up when i got it.  The wiring harness was speaker wire and wire nuts, the generator wires were melted, the license plate on the bike expired in 1984.  I got the bike from my BIL, he collects old Japanese bikes(and a couple old Bultacos), he bought about 50 from an old out of business bike shop, I helped him move them and he gave me the bike for helping.  I don't believe thats the original gas tank, but the underside is red/maroon, the two side covers are also black.
« Reply #6 on: August 18, 2021, 01:34:08 PM »
 Some states I believe and Wisconsin being one I think titled the bike by the numbers on the engine to further confuse things. Might of had a 73 engine at one time ? Your bike does have an early oil tank. When you open your gas cap on the tank do you see wrinkles in the metal ? Lot of other later model possible 73 parts on it also.
  Can you post a pic of the vin plate if it has one on the frame and the stamped serial number so we can see the style of the script.
« Last Edit: August 18, 2021, 01:46:36 PM by ekpent »
Offline Bankerdanny
  • Endeavor to persevere
« Reply #7 on: August 18, 2021, 01:43:53 PM »
That frame number would likely place it outside of the Sandcast range wouldn't it?
« Reply #8 on: August 18, 2021, 02:03:21 PM »
You are correct Danny, my mistake.  [for some reason I was thinking 14,000]
« Reply #9 on: August 18, 2021, 02:05:51 PM »
I see unicorn top triple...that is from 72 or earlier...your bike is a bitsa, bits of this, bits of that.  You have lots of research to do in order to figure out what bits are from what
« Reply #10 on: August 18, 2021, 02:07:09 PM »
He bought 50 bikes?!  Holy #$%*e!  He's got Eric beat....
Offline Mticar1
« Reply #11 on: August 18, 2021, 02:20:38 PM »
My BIL has upwards of 300, its his retirement plan, rebuild them and sell them, he's not good at sitting still.
I started down this road because I was looking on ebay for a front caliper and disc to do the dual disc conversion, and the seller said some 1973 bikes had k2 front forks and some had k3, and the brackets are different.  I looked at some parts diagrams, and I'm pretty sure its a k3 front end.  The title says 1973, and the engine looks like an early k3, I think its just the frame that's not k3.
« Reply #12 on: August 18, 2021, 02:23:27 PM »
 Just to clarify is the number on the title the number that is stamped on the frame ?
  Looks like a 71 or earlier tailight.
« Last Edit: August 18, 2021, 02:25:21 PM by ekpent »
Offline Mticar1
« Reply #13 on: August 18, 2021, 02:25:38 PM »
yes
« Reply #14 on: August 18, 2021, 02:30:08 PM »
What state is the title from ? Back in the day in Michigan they used to play pretty loose getting a lost title for any bike. Not so much now.  BIL means brother in law ??
Offline dusterdude
« Reply #15 on: August 18, 2021, 03:05:56 PM »
My 750 is a august 71 build k1 but titled as a 72
Sent from my LM-G850 using Tapatalk
mark
1972 k1 750
1949 fl panhead
1 1/2 gl1100 goldwings
1998 cbr600 f3
Offline Mticar1
« Reply #16 on: August 18, 2021, 03:29:09 PM »
Yes BIL is brother-in-law
It was titled in Illinois, but the title was dated 1998, but the tags for the bike expired in 1984.  I believe the bike was abandoned at the bike shop sometime in 1984, then the story I was told is someone started buy up old bike shops for the inventory.   The bike was "sold" in 1998, I'm guessing to the bike shop buyer, who when he got all the inventory spent sometime getting titles for all the bikes.  Anyway, my BIL got all the bikes 3 or 4 years ago, I helped move them and I got the bike.  I live in Maryland and I just went to the MVA today to title and tags. The MVA had no issues, gave me a tag, and I was on my way.
Offline jlh3rd
« Reply #17 on: August 18, 2021, 03:43:18 PM »
according to this, it appears your engine is earlier............K3 or lower....curious just  how early...
It's not sandcast status....but it's a KO.....what are your intentions?
    The thing is, practically everything for that bike can be purchased new....tank, covers, pipes, wheels, airbox, .....not cheap........but a few good options for you, i'd think..
Offline MrOuija
« Reply #18 on: August 18, 2021, 08:24:26 PM »
My CB550 has a build date 12/74 on the frame plate, but my title says it is also a 74 year model. Not sure what happened there.
« Reply #19 on: August 18, 2021, 11:01:28 PM »
You have a 69/70 oiltank, and that matches frame number. Your forks are73 or later as are your instruments. .
 There is an easy way to tell if that motor came with that frame. (And had cases changed)..
 Look in front of 2 and 3 plugs, is there a bolt between the two plugs but on the top fin, rear part of fin? I can sort of see in your pic, its not clear so I am not sure ? It appears no bolt., if that is true, then the head  is no later than Feb 70, and real good chance its the original motor.
 You are correct though, early 73 they still used that style of head but with center bolt.
Offline Kevnz
« Reply #20 on: August 19, 2021, 01:14:15 AM »
[/quot According to the numbers, my 550 had a 1974 frame, 1976 engine, and was registered new in 1980 as a 1977. 1977 was first year of the 550K, but by 1980 there was plenty of more sophisticated competition around; would have been a hard sell.
Good grammar: The difference between knowing your #$%* and knowing you're #$%*
« Reply #21 on: August 19, 2021, 02:57:44 AM »
oops...that is not unicorn top triple.  I will get off the crack now.
Offline Mticar1
« Reply #22 on: August 19, 2021, 04:11:37 AM »
It looks like there is a bolt hole between 2 and 3 exhaust ports, but no bolt.  I put a piece of wire down the hole and it seems to go all the way into the block.  Should I put a bolt in there?  Also, I did some research about the different heads and read about the production code stamped in to them between 2/3 intake, but my code doesn't look like any others.  Also I don't know if it means anything, but like I said before, when I got the bike the electrical system was a mess, the wires to the stator were melted, so I had to replace the stator.  When I pulled the cover off the oil galley plug was missing, I bought one on ebay and put it in, should I take it back out?
Thank you to everyone for all the help and info
Offline DickL
  • Really really old
« Reply #23 on: August 19, 2021, 04:36:52 AM »
When I bought my K0, a 3/70 build, five years ago, it had a 1974 motor, I found a matching motor , that was withiin  50 s/n, I sent motor to Hondaman for overhaul and now I have a restored matching number bike.
I would guess that your frame was a November 1969 build or sooner. A very early diecast. If I were you I would be patient and search for a matching S/n engine.
Meanwhile restore the frame to period correct condition. When done you might have something worth 20 to 25K
Dickl
1970 CB750
1999 Honda Valkyrie
Online 69cb750
« Reply #24 on: August 19, 2021, 05:17:54 AM »
CB750-1009821 was built in October 69.
My 69 diecast is near this vin.
« Last Edit: August 19, 2021, 05:19:50 AM by 69cb750 »
