Author Topic: What glue to use?  (Read 582 times)
Offline krksquared
    • Nostalgic Kits Central
What glue to use?
« on: August 22, 2021, 03:37:58 PM »
My label plate (says Oil - High Beam - Neutral) separated from its housing. Anyone have a recommendation for a good glue to re-install (not JB Weld)?
@kennectwithme
1975 CB400F
1971 SL350
1979 CBX
2007 Buell XB9R
2003 Harley V-Rod VRSCA
If it ain't broke, I'm riding...
Offline goodtryer
Re: What glue to use?
« Reply #1 on: August 22, 2021, 03:41:08 PM »
Contact cement. Follow the directions and it'll be on there for good.
"Tolerance will reach such a level that intelligent people will be banned from thinking so as not to offend the imbeciles."
-Dostoievski
1977 CB550K
1978 CB750K
1973 CB500K
Offline krksquared
« Reply #2 on: August 22, 2021, 03:44:03 PM »
Cool  :)
@kennectwithme
1975 CB400F
1971 SL350
1979 CBX
2007 Buell XB9R
« Reply #3 on: August 22, 2021, 03:46:33 PM »
Mix up a little bit of water with a few drops of white gorilla glue in a cup. It will foam up and expand...you want it to do this before you apply it. Then apply a very thin coat on the metal keeping a border free of glue near the openings and edges. Apply it to the base and rub it down to spread the glue. You want a very thin coating...a credit card to scrape an even thin coat across the back of the metal plate may help you.
If you can safely clamp it, then do so...
Polyurethane glue adheres dissimilar materials together very well.
Offline BenelliSEI
  • 1969 cb750
« Reply #4 on: August 22, 2021, 03:59:11 PM »
Totally agree. Thin coat both parts and let TOTALLY DRY. Caution, once they touch, no chance to re align! Contact Cement (good quality) used correctly is amazing stuff.
Offline jonda500
« Reply #5 on: August 22, 2021, 06:21:40 PM »
Mine had an annoying buzz, so I pulled it off, cleaned it (and the plastic) thoroughly and glued it back on with a generous coating of super glue - it's never buzzing or coming off again! I got lucky as super glue doesn't always stick well to plastic..
John
A starter clutch thread:
« Reply #6 on: August 22, 2021, 06:29:52 PM »
Offline Maltboy
  • Pitter-patter, let's git at 'er!
  • Making stupid mistakes since 1959
« Reply #7 on: August 22, 2021, 06:37:30 PM »
This is exactly what I used, but thinned a little with xylene so I could paint it on with a small brush.  Worked like a charm.
