Author Topic: Looking for video that’s posted on the main site  (Read 898 times)
Offline KennyRedman
  • 1976 CB550F, Indiana
« on: August 27, 2021, 05:04:00 AM »
Hey all- I’m looking for the video thats on the 550 page of the main site. The link seems to be wrong.
http://www.sohc4.com/cb550/cb550/
Online Stev-o
Re: Looking for video that’s posted on the main site
« Reply #1 on: August 27, 2021, 09:15:25 AM »
Doubt this is it, but appears to be a good video
Offline KennyRedman
« Reply #2 on: August 27, 2021, 10:55:37 AM »
Ya thanks, I’ve seen this series- very well produced. It’s interesting how he uses just one gauge and the manifold. Don’t think I’ve ever seen that technique.
Is it common to sync at over 2k? I’ve been doing it at idle; thought that was the idea.
Online Stev-o
« Reply #3 on: August 27, 2021, 11:29:05 AM »
Not common [or necessary?] to sync over 2K RPM, I also just do it at idle.
Offline samm_j2
« Reply #4 on: August 28, 2021, 07:41:38 AM »
I have not herd good things about using just that one gauge. I see some appeal as your using the same gauge but seems like a pain...
I thought you synced at around 2k and then re checked it at idle?
Offline jonda500
« Reply #5 on: August 28, 2021, 05:44:50 PM »
I also always sync at idle - at over 2000 rpm, well, I can't see it working as effectively with the lower vacuum at higher revs,
John
A starter clutch thread:
Online newday777
« Reply #6 on: August 29, 2021, 01:35:19 AM »
John
It was a common practice back in the 70s to check the 2,000-3,000 rpm level after at idle set per Honda techs of then.(as long as you used the dial gauges and not the Mercury gauges......)
Stu
My current rides
Prior bikes....
« Reply #7 on: August 29, 2021, 10:47:44 AM »
 I always wondered why not make up one really good gauge with a 4 valve manifold, checking each carb one at a time.
« Reply #8 on: August 29, 2021, 08:30:47 PM »
because changing one carb affects the others...turn one down and watch the other three go up or maybe only 2 or 1 or maybe not at all...so one gauge at a time becomes even more of a frustrating exercise in futility than usual
Offline Deltarider
« Reply #9 on: August 30, 2021, 04:13:26 AM »
I have no experience with a one vac. gauge set up, but I don't see why it shouldn't work. If differences in vac are not that far apart, it is a sensible and economic way imo. If differences are widely apart, it could be a bit difficult however.
Having said that, please note that readjusting the vacuum is rarely required (see below what Honda states in the Owner's Manual). First do all the other sceduled maintenance - in particular the ignition - and I bet most of you will have a nice running engine again.
CB500K2-ED Excel black
