Author Topic: Bonneville Bound  (Read 26607 times)
Offline richmagee7
Bonneville Bound
« on: August 27, 2021, 08:26:44 PM »
I was Bonneville bound when I first tried to post this before leaving the house Wednesday.  That post doesn't seem to have taken.  Anyway, at Bonneville now, or rather in Wendover NV now near the salt flats.  Bonneville motorcycle speed trials registration, pit setup, tech inspection and fuel tomorrow Saturday.  Land Speed runs start Sunday.
I've run my stock 75 CB750 here in '16, '17 and '19 in the stock classic (pre-1981) class.  Going to run a 1971 CB500 this year but will try some modifications.  That would be the modified classic gas class.  Mods include a Mike Rieck prepared head with oversize intakes, and everything that should go along with that, CR26 carbs, 4-1 Hindle exhaust from RippleRockRacers, HD cam chain from CycleX.  I went through the bottom end and installed new primary chain, crank was balanced by APE and stock rods shotpeened and installed with heavier rod bolts.  Per Mike's recommendation, sent my cam to Megacycle for their 126-20 grind with custom 110* lobe centers.  Dyna S ignition. Following that I screwed it up by not acting quickly enough to get custom pistons forged.  Started to run into trouble finding anyone who could forge pistons smaller than 58mm.  Finally was told some could be billet cut but the backlog would put me near my departure date.  Well the pistons didn't arrive as of last Friday so I put the motor together with the stock cam (I procured another) and pistons.
After getting the head bolt washer out of the engine where I dropped it, and getting the motor together and in, I got the bike started Saturday morning, got it actually running Saturday night and took it for a test ride Sunday morning in the neighborhood.  It just wouldn't get going, kept stumbling, finally quit.  Oh, gas was off.  Got her going again, tried to hit the throttle hard at 3500rpm, it hesitated for just a second, and then bam, the exhaust screamed, and it took the heck off, hit second and did it again.  I went home grinning ear to ear though it wasn't much of a test in the neighborhood streets.
I have no idea what it will do out here on the salt but at least I was able to bring a running bike.  Looking back just now at a post from 2017 you guys had so much great advice on tuning, gearing, dyno information, etc. that I wont be able to utilize until next year.  There is a fellow from Texas who I've spoken to but not met who built his own portable dyno and brought it to the salt this year.  He offered it up, we'll see.  But I am totally excited to be here again and I think I smiled the entire 1500-mile trip from Texas.
Looking forward to seeing Dennis and Jerry again, and thanks to Mike Rieck for all his work, time and advice.  I'll post a few pics and will report on the escapades for those interested.
Offline richmagee7
Re: Bonneville Bound
« Reply #1 on: August 27, 2021, 08:33:18 PM »
Some pics, having trouble posting, maybe files too large.
Offline richmagee7
« Reply #2 on: August 27, 2021, 08:37:16 PM »
JMR exhaust porting before and after, and bike ready as it will be for now.
Offline gschuld
« Reply #3 on: August 28, 2021, 05:00:38 AM »
Good luck out there….👍. Take lots of pictures.
George
Offline BenelliSEI
  • 1969 cb750
« Reply #4 on: August 28, 2021, 05:45:38 AM »
Watching and best of luck. That place is on my “bucket list”......
« Reply #5 on: August 28, 2021, 01:23:33 PM »
 Very cool, good luck and results out there.
 Hope you get to pit near or with Dennis.. be cool to have both bikes in one pit area..
 Wish all great results..
« Reply #6 on: August 28, 2021, 04:23:10 PM »
Hope you have good results on the salt and have fun. Critical your flush all the salt off asap afterwards from what I have read and seen of bikes and cars exposed to it. It works its way everywhere.
Offline richmagee7
« Reply #7 on: August 28, 2021, 09:03:38 PM »
Thanks for the well wishes.
754, Dennis is always a great help to me.  Pitted not too far away.
Rafster, you are right about the salt for sure.
Offline richmagee7
« Reply #8 on: August 28, 2021, 09:26:37 PM »
My bike with Dennis' bike in background along with Dennis Old Scrambler and Jerry RXMan.
Online scottly
« Reply #9 on: August 28, 2021, 09:41:52 PM »
Thanks Rich! Keep the updates coming!! 8) 8)
« Reply #10 on: August 29, 2021, 07:58:38 AM »
 Good luck and we'll be along for the ride in spirit.
Offline gschuld
« Reply #11 on: August 29, 2021, 10:33:43 AM »
file:///var/mobile/Library/SMS/Attachments/e0/00/84A86F74-F290-47E2-8B10-5D05A5584D32/video000000.3gp
Sorry this isnt uploading
George
« Last Edit: August 29, 2021, 10:37:44 AM by gschuld »
« Reply #12 on: August 29, 2021, 12:41:54 PM »
Are they running today already ?
Offline gschuld
« Reply #13 on: August 29, 2021, 04:38:12 PM »
I know Dennis did a run.  No news on how it went.
George
« Reply #14 on: August 29, 2021, 06:22:21 PM »
Rich had an initial run today that went well. 103 ?? for starters on a new bike.
Dennis got 2 runs in. First was 137? Then a 123 after dropping 2 teeth on the rear in an attempt to compensate. He wanted to try to run it through in 4th after dropping 1000rpm going into 5th on that 1st run. That didn't work well. He entered the km at 130 and cut the throttle when he felt like it was cutting out. Battery perhaps?? but not. The DA reading was at 6600' on his timing slip so he adjusted mains from 122.5 to 120's and did some carb checks. Salt, water and a little crud. Should be ready to run tomorrow after visiting the fuel station. Still running partial streamliner at this point.
I am bailing Tuesday morning for points beyond.
« Reply #15 on: August 30, 2021, 08:32:02 AM »
Good luck to you Rich!
Keep the updates coming...thx
Offline richmagee7
« Reply #16 on: August 31, 2021, 04:29:19 PM »
So, Sunday I made one run mid day after finally passing tech.  I had to build a metal chainguard because the one on my bike which I guess was stock was plastic.  Modified class so I needed metal.  Dennis to the rescue, I was able to fab one with some aluminum "cutoffs" he gave me.   The start point for mile one is much closer to the track than in the past.  You ride out when its your turn and turn left onto the track at mile one.  Dennis would be starting from mile zero.  Timing is from mile 2 to mile 3.  I am having trouble with the CR26 carbs below 4k rpm and stalled the bike when I got the go ahead for my run.  Stalled it twice more in the 50 yards to the track, kept thinking they are going to run up behind me and give me the hook, get out of here you.  It always fired back up, I'm using the stock alternator, battery, and electric starter.  New bike so tried to take it easy, track is so nice like a freeway that in fourth and fifth I let it run and went 103 as Jerry said.  Wouldn't get past 8k rpm
Monday I waited near 3 hours for a run as I also did yesterday.  My rearsets and shift linkage was loose, I messed up the shift and as rpms dropped those carbs couldn't take me hammering the gas and she quit and I turned off track and tried to get out of the way so others could run, only one bike on track at a time.  Fired it up and rode it back to pits.   Before going home I switched from 105 main jets to 100s, and flipped the shift linkage over so I would be 1 up and 4 down.
Tuesday I kept her lit till I hit the track, eased it to 4k and then hit it, revved up nice to redline 9200rpm which I used as shiftpoint, fourth gear took a bit to reach 9200, shifted just before timed section, rpms went to 8k in 5th gear, and then stayed there.  Felt so much better, but still at 8k in fifth so went 104mph.   Next run I let it rev to 10k where I shifted and stayed in 4th, hit the timed section at 9800rpm and she only climbed to 10k, went 106.  Talked to Dennis about how safe to rev much more, he said let her rip.  Tomorrow I'll make a run in morning coolness and see what happens.  I'll try to take more pics.   Dennis ran about same today as yesterday I believe, I'll let him tell it.  Very hot today, with lots of smoke from California.
« Reply #17 on: September 01, 2021, 08:37:12 AM »
Great update, thx Rich!
Offline richmagee7
« Reply #18 on: September 01, 2021, 10:08:35 AM »
Wednesday, too windy to run so far, noonish and seems calmer, but no bikes on course.
Offline richmagee7
« Reply #19 on: September 02, 2021, 08:05:17 AM »
Racing resumed mid day Wednesday, helped Dennis with one run, then made a final run.  She revved to 11k pretty easy in first 3 gears, topped out at 10,500 in 4th which was only 500 rpm quicker than yesterday's last run, so I shifted to fifth before the timed mile, went thru the mile at 9k in 5th.  Ran 109.4mph.  Packed her up.  Great week, learned a lot, saw old friends, met new folks.  Thanks again for help Dennis and Jerry, thanks Mike Rieck for head work, this thing PULLs from 5-9k, can't wait to get cam and pistons in.
Few pics below including one of an RD400 which bumped record in this class from 113 to 128.
Offline richmagee7
« Reply #20 on: September 02, 2021, 08:07:10 AM »
Waiting for opening on Saturday.   The smoke from California is helping keep the heat down I believe.
Offline richmagee7
« Reply #21 on: September 02, 2021, 08:08:07 AM »
Entrance
Offline richmagee7
« Reply #22 on: September 02, 2021, 08:09:59 AM »
The Kraken and the RD400.  Kraken running two Hayabusa engines but only making test passes.
« Reply #23 on: September 02, 2021, 08:22:02 AM »
Rich, great pics. Sounds like you had fun and have the salt bug now. Look forward to seeing next year's runs with the upgraded parts installed and the bike tuned.  109.4 is a pretty good number for stock displacement motor with a massaged head.
« Reply #24 on: September 02, 2021, 10:38:36 AM »
 Sounds good everybody is having fun . 109 is good..
 Them guys in the Kraken pic gonna learn that shorts on the salt is hard on the legs, the sun rflects hard ofv the salt.. Znd a hat is a must, wide brim even better..
