Support the site. Your contributions keep this site running.
Based on what I see here, I’m leaning towards head gasket. But I’m interested to hear other more experienced thoughts.
Quote from: fxef79 on August 28, 2021, 03:47:25 PMBased on what I see here, I’m leaning towards head gasket. But I’m interested to hear other more experienced thoughts. Is this on a 750??? Ya gotta tell us what yer workn on when asking a question.If it's a 750??? Yes the pucks are the usual cause of oil in the fins.
If its the pucks for sure then the cam and cam towers would need to come out but the head can stay on. Fun part is the engine has to be out also unless you have a frame kit.
There are areas inside the fins that let oil flow down to the cylinder top.
Quote from: Don R on August 29, 2021, 08:50:04 AM There are areas inside the fins that let oil flow down to the cylinder top. Guess I’ll be pulling the cam and towers then.
Do a compression test if you suspect a head gasket. But, if it checks good, I don't think it does much to keep in the oil. Pucks, o rings, seals, etc. contain the oil, AFAIK. Of course, to change some of those the head must come off.Cheers,
