I recently purchased a '72 CL350 with a known oil leak somewhere just above the starter motor. Bike has 25000 miles and runs will with no unusual sounds and noises. Has good compression. It was last on the road in 1983 and left in a barn. Today I cleaned years of grease, oil and dust off the front and bottom of the engine to search for the leak and found it. The leak is slow and not a gusher. The head gasket is not the problem. Just above that there is a shiny rough spot on the cylinder where the cam chain is. I've tried to get a good picture but the spot is back in the bottom recess. Don't know if it's a casting failure or maybe something with the cam chain caused it to wear through. Thoughts?
