Author Topic: Oil pump direction  (Read 461 times)
Offline beemerbum
Oil pump direction
« on: August 29, 2021, 05:59:36 PM »
If installed in a 750 motor that is running, would the gear be turning clockwise or counter clockwise?
Offline flybackwards
Re: Oil pump direction
« Reply #1 on: August 29, 2021, 07:04:50 PM »
Bravery required on this answer.. Crankshaft rotates CW viewed from the points cover side - so clutch drum rotates same way so the large intermediate gear on the kick start shaft is going CCW and that would make it that the oil pump gear turns CW.
