Hello again,
I am stripping down a CB750 K0 engine. All completely stripped except I can’t separate the the head from the cylinders. When removing the head from the engine the cylinders and head came together.
All of the fasteners including the rear 6mm bolt are removed, but it’s stuck. Obviously I don’t want to force it apart and break something. My usual method of separating stuck items is heat, either a hot air gun or butane torch.
The head and cylinders is way to big for this, I would not get enough heat into it.The only way I can think of getting it hot enough is to put in on the BBQ!
The rubber parts will all be replaced, so I am not concerned about them.
Is this a bad idea?
