Sorry to revive an old thread - but I finally got the time to pull the engine over the weekend. Sleeves appear to be pretty pitted in several places (probably caused me to burn oil - which would explain the smoky exhaust issue ive always had).
My friend, who is a diesel mechanic, was of the opinion that the pitting is pretty substantial and recommended I have the sleeves bored and honed.. so gotta tack that on to my shopping list.
What's the normal if you have to bore your sleeves out some? is there a certain amount that you can make up for using rings? or do you always have to go up a piston size as well? OEM honda pistons are scarce on ebay.. let a lone a set of 4.
My plan for now is to call CycleX tomorrow and see where theyd be at. Last time I called, they didnt seem to think highly of the bronze valve guides - so he may spit in my face if i tell him thats what I want...
Plan on having them quote:
1. Head resurfacing
2. Valve guides
3. New Valve retainers
4. Bore and hone cylinders
In the mean time.. just have to continue the internal struggle regarding the bottom end "to split the cases.. or not to split the cases..."
Here are some pics of the sleeves:
Cyl 1 &2
Cyl 3&4
