Author Topic: CX-12-84 cam experience?  (Read 1502 times)
Offline gschuld
« on: September 09, 2021, 04:39:38 PM »
Does anyone here have experience with the big CycleX CX-12-84 cam?
It’s both high lift and long duration.  Lift matches the CX10 but with much longer advertised duration.
George
Offline Old Scrambler
Re: CX-12-84 cam experience?
« Reply #1 on: September 09, 2021, 05:10:41 PM »
Very similar but slightly more aggressive than my custom Megacycle 125-x29. If you use that cam in a 300 head you will have to machine the valve pockets. At that lobe-distance you will have very little room to advance or retard the cam.
Dennis in Wisconsin
'63 CL72 Project(s)
'66 CL77 Red
'67 Triumph T100C
'73 750K3 Owned since New
'77 750F2 Cafe Project
2020 ROYAL ENFIELD Himalayan
Online MRieck
« Reply #2 on: September 09, 2021, 09:27:31 PM »
You might be better off using the 32mm intake valve to get the valve to valve clearance. RC engineering did that with their large cams.
Offline gschuld
« Reply #3 on: September 09, 2021, 11:24:30 PM »
Hmm.
Thanks Dennis.
Mike, I didn’t know RC used 32 intakes on their biggest cams.  By biggest I assume you mean the RC454 cam?  .390/.390 lift with a huge duration rounded love shape.  That’s good to know as I have one of those cams.  The 32 intake might not be so bad with a forced induction or nitro engine.
But for naturally aspirated on race gas, using a 32 intake would seem to be going backwards.
My potential use would be for a 997cc to 1026cc high compression road race(maybe Bonneville once?) engine.
George
« Last Edit: September 09, 2021, 11:42:35 PM by gschuld »
Offline NitroHunter
  • Radical Street / Strip Turbo
  • A man's motorcycle is a reflection of the man
« Reply #4 on: September 11, 2021, 09:06:49 AM »
In the 34mm intake F-2 head even the much milder RC 315 cam had valve-to-valve clearance issues, I was told strait out by RC that cam wouldn't work in that head. Reducing to 33.5 (Manleys) didn't make that much clearance difference except because being stainless and not stellite coated, they could be ground a little around the edge, then they quit hitting most of the time when you missed a shift. Man we thought we were so smart.
Robbie the NitroHunter                      Fuel Coupe Hired Gun                  NHRA T/F 640
DRAGBIKE USA XH/MB Recordholder: http://forums.sohc4.net/index.php?action=dlattach;topic=127179.0;attach=332735
DRAGBIKE USA XH/SS Recordholder: http://forums.sohc4.net/index.php?action=dlattach;topic=63940.0;attach=103300
Young mans glory days in the lanes: http://forums.sohc4.net/index.php?action=dlattach;topic=45685.0;attach=66341
Online MRieck
« Reply #5 on: September 11, 2021, 02:50:49 PM »
Hmm.
Thanks Dennis.
George
Not if you leave it open for 75% of the cycle. ;D
Offline gschuld
« Reply #6 on: September 11, 2021, 04:25:46 PM »
Yeah, yeah Mike.
So out of curiosity, were any of the naturally aspirated RC race engines using big cams and 32 intakes(like the early top gas bikes or the Vance and Hines double), of just the power added bikes(nitro counts)
For NA race engines, thee must be a trade off between larger valves and smaller cams and smaller valves and larger cams.  Then there is the variable of sinking the valves deeper, the deeper you go the more clearance you get, but at the sacrifice of chamber volume and stem height geometry issues at the rocker.
George
« Last Edit: September 11, 2021, 04:28:37 PM by gschuld »
« Reply #7 on: September 11, 2021, 06:13:25 PM »
Consider smaller exhaust valves to gain overlap clearance.
Also consider that the actual opening and closing events may be a degree (or several) different from the spec on the cam-card.
Dennis in Wisconsin
'63 CL72 Project(s)
'66 CL77 Red
'67 Triumph T100C
Offline cbr954
« Reply #8 on: September 11, 2021, 08:37:04 PM »
I just bought this cam and have it in my motor to check clearances.  Valve to valve had no issue in my RC head  33.5 intake stock exhaust.    Exhaust to piston clearance was fine, intake to piston was close....had .030" clearance.  Cam was degreed to the card specs.  Havent gotten any further on the build.   72mm MTC 12:1 pistons
03 CBR954RR, 72 750 chopper(970cc
F2 head), 2017 CRF450R, 2001 CR250R, 72 CB500, 79 XR250, 04 CRF50,70's soon to be rebuilt cb750 drag bike.
Offline gschuld
« Reply #9 on: September 12, 2021, 05:24:39 AM »
That’s positive news thanks…..
George
« Reply #10 on: September 12, 2021, 06:07:36 AM »
+1
Offline gschuld
« Reply #11 on: September 12, 2021, 06:38:01 AM »
Yes shrinking the exhaust valve is a proven method. It will definitely be kept in mind.
George
