Author Topic: Resto Honda CB500K1 1972  (Read 3728 times)
Offline CB500K1
    • Restoration Honda CB500K1 1972
Re: Resto Honda CB500K1 1972
« Reply #25 on: March 04, 2022, 02:18:28 AM »
The rebuild engine is back in the frame ;D
Here some more pics:
https://hondacb500k1.blogspot.com/2022/03/honda-cb500k1-engine.html
« Reply #26 on: March 04, 2022, 08:38:32 AM »
Looks great!  15 hours to clean the engine case??!!
Offline CB500K1
« Reply #27 on: March 05, 2022, 01:40:50 AM »
Yeah, it was very fiddly to clean out every little corner. for 2 weeks, every evening an hour or so.
Offline CB500K1
« Reply #28 on: May 16, 2022, 04:12:02 AM »
It's been a while but after fixing a couple of electrical gremlins the CB500K1 resto is nearing completion  ;D
 https://hondacb500k1.blogspot.com/2022/04/honda-cb500k1-1972-wiring-stuff.html
Offline CB500K1
« Reply #29 on: May 26, 2022, 08:59:38 PM »
The CB500 is finally back together and yesterday I took it to an ID-inspection station to get it registered. All good ;D
All in all it took me a year to get it back on the road, really happy with the results thanks to all the info available on this excellent forum ;)
See more pics at: https://hondacb500k1.blogspot.com/2022/05/honda-cb500k1-reassembly.html
Offline Shtonecb500
    • Youtube profile
« Reply #30 on: May 27, 2022, 06:34:26 AM »
looks very nice.
73/74'' CB500/550 resto-mod - sold
75' 750f 91' cbr f2 swap cafe - mock up
74' 750 chopper hardtail - complete - sold
74' CB750/836kit - Black mix & match - daily rider - always tweaking
71' cb500 K0 survivor - complete
71' K1 - CANDY GOLD/BROWN Winton kit - in process
« Reply #31 on: May 27, 2022, 01:29:17 PM »
Great job!  I am nominating you for Bike of the month!  Plz go here to accept...
http://forums.sohc4.net/index.php/topic,180400.0.html
Offline CB500K1
« Reply #32 on: May 27, 2022, 03:27:28 PM »
Tnx, Such a great honour ! :)
Offline Little_Phil
« Reply #33 on: May 28, 2022, 03:04:39 AM »
Looks great. Looks like a bit of profit there for CMSNL and the postal services.
Are you going to use it or is it going in the living room?
Offline MauiK3
  • A K3 is saved
  • Old guy
« Reply #34 on: May 28, 2022, 08:23:23 AM »
Beautiful bike!
1973 CB 750 K3
10/72 build Z1 Kawasaki
Offline CB500K1
« Reply #35 on: May 29, 2022, 01:34:11 AM »
Tnx guys, yeah a lot went into shipping ;)
I'm gonna use the bike, but as I put it on historic rego, you can only use it for 90 days a year.
More than enough for me  8)
For now I'll keep it in the lounge because that's climate wise way better than in the shed and I can have a look at it every now and then.
Offline CB500K1
« Reply #36 on: June 18, 2022, 05:35:17 PM »
Yesterday I took the CB500 for a spin. Beautiful winters day.
It runs perfect, no flat spots, no leaks, no weird sounds from the engine, all good.  the only little thing that annoys me is the noise coming from the front brake. I used copper grease at the back of the pads when I installed them.. maybe they have to wear in? The brake works fine and doesn't run hot.
I was also wondering if I should change the oil earlier than normal after the top end rebuild or not?
Anyway some pics from yesterday :)
Offline Hurricane6
« Reply #37 on: June 19, 2022, 03:41:17 AM »
Beauty
Offline newday777
« Reply #38 on: June 19, 2022, 04:01:16 AM »
Well done on your bike.
Brake squeal
http://forums.sohc4.net/index.php?topic=24769.0
Oil early change is probably a good idea
Stu
My current rides
Prior bikes....
Offline CB500K1
« Reply #39 on: June 29, 2022, 12:22:49 AM »
Tnx guys, will look into the squeal next weekend.
Offline Shtonecb500
    • Youtube profile
« Reply #40 on: June 29, 2022, 06:34:41 AM »
Offline CB500K1
« Reply #41 on: July 14, 2022, 01:49:17 AM »
Hi I was wondering if someone has tried to split the headlight unit in order to clean/dry the inside of the glass. I think mine is still  the original one with the big round bulb. According to the parts manual it's one part and not splitable.
Offline newday777
« Reply #42 on: July 14, 2022, 03:05:28 AM »
If it is the sealed beam don't try it. Get a new sealed beam or upgrade to a H4 bulb headlight for far better light to see down the road.
Stu
My current rides
Prior bikes....
Offline newday777
« Reply #43 on: July 14, 2022, 03:19:58 AM »
The reason not to try to open up a sealed beam headlight is they use an inert gas in them so unless you can replicate the process to vacuum suction shell after you reseal it and inject the gas, you bulb will not put out the light brightness any longer.  Back in the 90s I went to a friend who showed my the process that Phillips did to inject the gas. It was a big plant.
https://blog.betterautomotivelighting.com/2
Stu
My current rides
Prior bikes....
Offline CB500K1
« Reply #44 on: July 14, 2022, 04:15:18 AM »
Wow, excellent info. The little boy in me still wants to take it apart but I'm also gonna order an original looking upgrade.
Offline Little_Phil
« Reply #45 on: July 14, 2022, 07:49:51 AM »
If Australia is like UK we did not have the sealed beam. It had a 35/35W separate bulb I think and a separate 5W (P) pilot bulb. (do you have a P position on your RHS switch?) The silvering on original lights will invariably be degraded and not easy to fix.
Offline CB500K1
« Reply #46 on: July 15, 2022, 03:45:53 AM »
It's a sealed headlight from Stanley (see pics). I recon there's no gas in it anymore as moist found a way in, gas must have found a way out. The replacements are all without the pilot light hole in it. I would like to upgrade to H4 but also keep the original round glass shape and pilot light.
Offline CB500K1
« Reply #47 on: July 15, 2022, 04:05:44 AM »
Phil, There's no P on the RHS Switch
Offline CB500K1
« Reply #48 on: July 16, 2022, 01:10:38 AM »
Offline Little_Phil
« Reply #49 on: July 18, 2022, 03:59:01 AM »
Strange headlight, looked at CMSNL and indeed Australia had a sealed beam version of the UK, replaceable bulb type. But it does have the separate opening for a 5W pilot light. Probably just use as a parking light in Aus if you do not have the P.  In the UK we were allowed to drive with just the 5W illuminated in some conditions. Different country regs. US bikes do not have it.
Example shown may well be fine.
