Author Topic: CB750K Transmission Oil Change  (Read 3316 times)
Offline David Beecham
« on: September 14, 2021, 01:23:50 PM »
I recently purchased a '74 CB750K. Bike starts, runs, shifts and drives fine. Along with some other maintenance items, I want to change the transmission oil. Is that a recommended maintenance item? I ask because transmission oil change is not covered in my SHOP MANUAL. How do you drain and refill the transmission oil?
Offline Flyin900
Re: CB750K Transmission Oil Change
« Reply #1 on: September 14, 2021, 01:28:50 PM »
Oh boy. :)
Your oil in the motor is the only oil the bikes uses. It lubricates all internal components such as the wet clutch, transmission and motor.
Since you have the shop manual spend time reading over the general areas covered for regular maintenance.
« Last Edit: September 14, 2021, 01:30:42 PM by Flyin900 »
1978 CB550K - Super Sport
1982 CM450A - Hondamatic
1982 CB900C - Custom
1983 CX650E - Eurosport
« Reply #2 on: September 14, 2021, 01:47:23 PM »
Hey David...welcome to the forum.  Click here for the info you asked about.
Nearly everything you wonder about can be found on the website!
http://www.sohc4.com/tech/cb750-faq/
The real question should be what is the best oil to use?!
« Reply #3 on: September 14, 2021, 02:44:49 PM »
Thanks for the link. Good stuff. The previous owner told me that the trans oil was separate....
For oil I generally use Rotella 15-40 or Castrol Semi Synthetic 20-50, both are JASO MA2. Any reason not to use the Castrol?
« Reply #4 on: September 14, 2021, 03:15:17 PM »
Never believe a seller!
I use Rotella and avoid synthetic since this has a wet clutch [could cause slipping] and minor weeping at gaskets.
Can you post a pic of your bike?
Offline newday777
« Reply #5 on: September 14, 2021, 04:01:34 PM »
Welcome aboard David and to the 750.
The Rotella will run fine in your 750 if you aren't riding it hard and fast in high heat.
I generally run 20w50 Honda oil in the heat of summer and cooler temps run the Rotella for easier start ups.
Stu
My current rides
Prior bikes....
« Reply #6 on: September 14, 2021, 06:55:23 PM »
Pic attached
Offline grcamna2
« Reply #7 on: September 14, 2021, 10:27:16 PM »
Welcome to the forum David.That's a Very beautiful CB750 !  8) Do you know if that bike has been restored once? or is original,a 'Survivor'? I run the Rotella T4 15/40 myself year-round,works good for me.
Offline Kevnz
« Reply #8 on: September 14, 2021, 10:54:17 PM »
That is one very nice looking bike. Love that colour, 1974 only, I believe.
Good grammar: The difference between knowing your #$%* and knowing you're #$%*
Offline disco
« Reply #9 on: September 15, 2021, 01:33:52 AM »
Love the funky purple colour. We never got that one here in Australia. Very nice looking machine.
1976 CB750 K6 Sapphire Blue
1972 CB750 K2 Candy Red
1972 CB750 K2 Candy Gold'
Offline newday777
« Reply #10 on: September 15, 2021, 03:03:41 AM »
Pic attached
Great looking in Boss Maroon. (Funky purple in AU!)
And yes 1 year only color.
I have the 75 1 year Planet Blue(in the USA market.... European markets had Planet Blue with small stripe on the K2 available)
« Last Edit: September 15, 2021, 03:09:13 AM by newday777 »
Stu
My current rides
Prior bikes....
Offline 74CB750K4
« Reply #11 on: September 15, 2021, 04:01:16 AM »
Definitely a nice one!! My dad ordered one in that color in 1974 and could never get one and stumbled upon the flake orange instead and took what he could get since they were so popular.
1974 CB750 K4 Flake Sunrise Orange
« Reply #12 on: September 15, 2021, 07:10:11 AM »
Pic attached
Great looking bike!  [my K4 was originally Boss Maroon]
Where did you find it?
« Reply #13 on: September 15, 2021, 09:42:18 AM »
My 74 CB550 was Boss Maroon when I got it.  It's brown now, as the sun bleached out all the red pigment.
Offline Mantree
« Reply #14 on: September 25, 2021, 08:19:30 PM »
I can conferm that the transmition and engine share the same oil.
Online PeWe
« Reply #15 on: September 26, 2021, 12:24:43 AM »
About oil for CB750
Make a Google search like
sohc forums + Spectro
Several hits on that.
Example:
http://forums.sohc4.net/index.php?topic=119643.msg1754367#msg1754367
About synthetic. My K6 use synthetic of good brand, Redline 20W-50. No clutch problem due to the oil despite 90-100whp.
A stock engine has less need of that kind of oil.
Using car oil one way to get clutch slip with anti friction additives car oils have.
Motorcycle oil for wet clutch the safe card.
Spectro 20W-50 mineral recommended on this forum. One member (ofreen)  has a very longed lived bike without restore on that oil. That's why I tried it after reading the zinc values as well.
You will feel when using an OK oil.
Find neutral when hot engine is standing still idling.
About zinc additives. Some are made for cars and have anti friction stuff in it too.
« Last Edit: September 26, 2021, 12:39:13 AM by PeWe »
« Reply #16 on: September 26, 2021, 03:53:26 AM »
Pic attached
Welcome!   Great looking bike.
Offline MauiK3
  • A K3 is saved
  • Old guy
« Reply #17 on: September 26, 2021, 07:51:19 AM »
Very nice bike.
Try to find a good shop manual, it will really help you.
1973 CB 750 K3
10/72 build Z1 Kawasaki
