Hi guys. New member here and thanks for letting me join up. I have a '74 XR75 that needs machine work: valve job, cam bearings, cylinder bore and new piston. I have not been able to find a shop that has the small tooling required for this bore and also have not found someone who knows how to deal with the pressed-in journal cam bearings.
The local shops here (central Calif) either don't have the small tooling or don't know how to deal with the cam bearings.
Can you guys recommend anyone who can do the machine work on these engines?
Thank you in advance! Pete
