Author Topic: #2 and #3 Running Rough  (Read 2088 times)
Offline Freebirdbeachbum
  • I don’t want a pickle, ...
« on: September 20, 2021, 04:57:26 PM »
I wouldn’t think they’d be related but after installing new 4:4 exhaust, it appears #2 and #3 aren’t running smoothly, almost like they are somewhat fuel starved. I believe it’s numbers 2 and 3 as those headers don’t seem to be as hot as #1 and #4.
I’ve taken two test rides and the problem starts and stops and starts again.
Ideas?
1972 Honda CB 750
1980 Honda CX500 Custom
1968 Wards Riverside Benelli 125
2017 Triumph Tiger Explorer XRT
2021 Lance Havana Classic 125
1965 Moto Guzzi Lodola Gran Turismo
Re: #2 and #3 Running Rough
« Reply #1 on: September 20, 2021, 09:18:12 PM »
2&3 operate on the same coil, point set and condenser. So check ‘em.
What do the spark plug deposits tell you?
Offline Deltarider
« Reply #2 on: September 21, 2021, 01:27:29 AM »
Was installing a new exhaust system the only thing you've carried out, or have you done maintenance? For instance, have plugcaps been removed?
Have the headers been properly mounted with new gaskets? Any new sounds (like ticking) there?
A check of the 2+3 ignition would include:
Are plugcaps firmly connected to their wires and are resistances correct?
In case you have the stock ignition, it wouldn't harm to have a look at the ign plate to check for possible arcing of the 2+3 breakerpoints which would indicate a faulty condenser. This vid may be helpful.
At the breakerpoints a bit of sparking is normal, excessive sparking or arcing is not good and can indicate a bad condenser. In this vid the left condensor (1+4) is bad, right condensor (2+3) is good.
Video: courtesy Ulf Penner
« Last Edit: September 21, 2021, 01:37:09 AM by Deltarider »
CB500K2-ED Excel black
« Reply #3 on: September 21, 2021, 01:51:11 PM »
I’m not seeing anything like that. Do condensers that are “bad” work sometimes and other times not?
Are there any other systems that serve only 2-3 or 1-4 besides the ignition system?
1972 Honda CB 750
Online newday777
« Reply #4 on: September 21, 2021, 04:05:23 PM »
That's a good video example.
A loose barrel connectors could give that occasionally cutting out and going back on.
Stu
My current rides
Prior bikes....
Offline Deltarider
« Reply #5 on: September 22, 2021, 02:28:38 AM »
Freebird, you haven't answered my question.
« Reply #6 on: September 23, 2021, 07:33:25 AM »
Sorry. No other maintenance was done. Only exhaust replacement with new gaskets. No new noises.
1972 Honda CB 750
« Reply #7 on: September 26, 2021, 09:00:44 AM »
Turns out it was the 1-4 condenser.  I replaced the condensers recently from a tune-up kit and it seems this one failed so I’ve now ordered some Toyo brand.
Thanks all.
1972 Honda CB 750
Offline Deltarider
« Reply #8 on: September 27, 2021, 12:16:30 AM »
Strange, although I have seen it before. Someone had the 1+4 breakerpoints doing the 2+3 coil, since his advancer had accidentely been reassembled a 180o wrong. :)
« Reply #9 on: September 29, 2021, 02:00:47 PM »
It's funny that I deduced it was 2-3 because the 2-3 headers didnt seem to be as hot as the 1-4 based on my spraying some water on each of them. The water on 1-4 evaporated instantaneously while the water on 2-3 lingered a fraction longer.
I was so focused on 2-3 that I didnt notice that the 1-4 points were the ones arcing excessively. The 2-3 points and condenser were fine.
I gapped them and set the ignition timing and it's running great now. Is there a better 70s era bike than the CB750?
Thanks again all.
1972 Honda CB 750
Offline Kevnz
« Reply #10 on: September 29, 2021, 02:48:29 PM »
Yes, the CB500 :D
Good grammar: The difference between knowing your #$%* and knowing you're #$%*
« Reply #11 on: September 29, 2021, 04:28:18 PM »
Yes, the CB500 :D
the 750 is at least 1.5 times better than the 500.  ;D
1972 Honda CB 750
Offline Kevnz
« Reply #12 on: September 29, 2021, 04:32:07 PM »
How good must a Harley then be? 2.4?
« Reply #13 on: September 29, 2021, 06:46:09 PM »
Yes, the CB500 :D
If not accounting for weight and higher Center of gravity. :-)
