Author Topic: What tank liner should i use? (10% ethanol)  (Read 1534 times)
Offline Korven
« on: September 26, 2021, 11:28:11 AM »
Ive came across a MuscleMachine kit. But as many of you know, the glassfiber its made of dont like the ethanol in todays gas. I basically could buy two 2 Liter non-ethanol jugs from the hardware store and run it with. However since the tank is quite small this wont be a good option, atleast not on longer rides. Are there any good liners out there that work with glassfiber?
I would prefer if i dont have to cut the tank up to apply it.
Offline grcamna2
Re: What tank liner should i use? (10% ethanol)
« Reply #1 on: September 26, 2021, 11:42:37 AM »
I had a customer who brought me a beautiful,low mileage original Norton 750 Commando which has a fiberglass tank;inside the tank it looked a little 'hairy' in a couple spots,like possibly some of the original resin was getting degraded.The paint on the outside of the tank was original black with gold lettering and stripes and it was Mint.
I was living on an island at the time and we have many boat repair places.I brought the tank to them after carefully masking off the outside of it and they did a 'Gel Coat' on the inside and it seemed to work well;they do the same thing with their boats with fiberglass fuel tanks.
There may be better options than that but it worked for my customer.
« Last Edit: September 26, 2021, 04:56:46 PM by grcamna2 »
75' CB400F/'bunch o' parts'
« Reply #2 on: September 26, 2021, 03:31:41 PM »
Caswell epoxy liner would be my choice for a fiberglass tank. May wish to download the instructions to see if you need any special prep for the tank given it is fiberglass and not metal.
Offline dusterdude
« Reply #3 on: September 26, 2021, 03:58:45 PM »
I have por15 in my gpldwing tank
Sent from my SM-G973U1 using Tapatalk
mark
1972 k1 750
1949 fl panhead
1 1/2 gl1100 goldwings
1998 cbr600 f3
« Reply #4 on: September 26, 2021, 04:10:12 PM »
Is your tank fiberglass?
« Reply #5 on: September 26, 2021, 05:21:00 PM »
    Caswell is the one to use on fiberglass.
Online BenelliSEI
  • 1969 cb750
« Reply #6 on: September 26, 2021, 05:40:58 PM »
I have used Caswell on two steel tanks and plan to use it on my fibre class Rickman tank. My research suggests this is the most likely to work. Ultimately I may order an alloy “replica” and save the glass tank......
« Reply #7 on: September 26, 2021, 05:50:47 PM »
 I used Caswell on my lightly used Fibermold fiberglass tank, it had not had gasohol in it ever. I got the large size to maybe do two tanks. I wasn't positive it was covering so I mixed the other half and used it all. I could see it through the bottom of the tank with a good light shining in the top and could get an idea of the coating. If it was warmer in the shop it might have covered with half of it.
 I believe it directed me to rinse with acetone first but read it for yourself.  I have only had gas in it once.
Offline dusterdude
« Reply #8 on: September 27, 2021, 02:12:22 AM »
No,steel
mark
1972 k1 750
1949 fl panhead
1998 cbr600 f3
Offline markreimer
« Reply #9 on: September 27, 2021, 06:26:32 AM »
Caswell gets my vote too
Offline 574hondarider
« Reply #10 on: October 06, 2021, 11:11:34 AM »
I used Caswell.  I was told by them to avoid using fuel stabilizers in it in the winter, so I've been draining the tank for storage.
Offline Kenzo1979
« Reply #11 on: October 12, 2021, 07:48:43 AM »
Jeez, it pays to read these posts even if you think you have nothing to offer.  I have caswell coatings in all of my tanks and had no idea you should avoid stabilizer in the winter.  After seeing this post, I immediately contacted Caswell to confirm and see what else I could be unaware of.  I will say I have not noticed any ill effects yet and it may depend on the brand of stabilizer (I use STA-BIL).  Got some good info from them, waiting on more.  Here’s what they’ve told me so far…
“…Some fuel stabilizers have ingredients that are close to that of paint stripper“
When I asked them about other additives such as seafoam…
“… Sea foam is fine. Stay away from Marvel mystery oil and three in one oil“
I’ll post more info if/when they get back to me.  The last message I sent them was asking for the specific chemical ingredients that may be in fuel stabilizers; waiting on a response.
--Kenzo
** 71 CB500, 74 CB550, 76 CB400F, 77 CJ360t **
Offline Kenzo1979
« Reply #12 on: October 12, 2021, 09:30:25 AM »
So…”Methylene chloride and dichlorobenzene are the 2 ingredients to keep away from” your Caswell (and probably most other) tank coatings.  So check those labels.  Good to know.
--Kenzo
