SOHC/4 Owners Club Forums
Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
The
SOHC/4 World Tour
is in under way.
Home
Help
Login
Register
Donate
Tech Forums
High Performance and Racing Forum
(Moderators:
Sam Green Racing
mlinder
Topic:
piston pin size
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: piston pin size (Read 1023 times)
Don R
My Sandcast is a
Really Old Timer ...
Saver of unloved motorcycles.
piston pin size
on:
October 02, 2021, 11:31:39 AM »
This may be a silly question but what are the odds an old build 3mm stroker 750 with aluminum mtc rods has bigger piston pins? My guess is 17mm, I want to order a machined dowel to check for a bent rod. Or am I wise to wait and measure them when it's finally back apart?
Logged
754
Re: piston pin size
Reply #1 on:
October 02, 2021, 05:38:02 PM »
Waif till its apart. Probably 15mmbut you never know. If you have a lathe you cann make the pin easily.
Logged
Kelowna B.C. Canada
scottly
Global Moderator
Humboldt, AZ
Re: piston pin size
Reply #2 on:
October 02, 2021, 07:53:18 PM »
Don, if you suspect the binding is caused by a bent rod, remove the cylinders. If the crank still binds, it's not a rod. I still suspect the welded crank is not quite straight, which is why it only binds in one place...
Logged
754
Re: piston pin size
Reply #3 on:
October 02, 2021, 08:54:11 PM »
Dies nit a bent rod usually make a distinct wear pattern in the bore ?
Logged
Kelowna B.C. Canada
Don R
My Sandcast is a
Re: piston pin size
Reply #4 on:
October 03, 2021, 05:09:34 PM »
I need to just take it apart one bit at a time and put this matter to rest. I would also expect to have seen wear in the old bearings or cylinder walls if the crank or a rod were bent.
Logged
gschuld
Master
Re: piston pin size
Reply #5 on:
October 03, 2021, 06:28:12 PM »
3mm stroker is very odd too. Why weld up a crank for 3mm? Or do you mean 6mm stroker crank(common) with 3mm shorter MTC rods to even out deck height?
MTC aluminum rods have plenty of meat to bore out to 17mm pins though.
George
Last Edit: October 03, 2021, 06:44:14 PM by gschuld
Logged
Don R
My Sandcast is a
Re: piston pin size
Reply #6 on:
October 04, 2021, 05:51:39 PM »
Probably 6, I lost my measurements. I figured 1123 or 1124 cc. The PO's kids called it a 1200.
Logged
Print
Pages: [
1
Go Up
« previous
next »
Tech Forums
(Moderators:
Sam Green Racing
mlinder
Topic:
piston pin size
