Hi everyone,
I could use some help figuring out what may be the cause of this abnormal noise. Thank you in advance, and my apologies for being absent!
Background: Went to shift 2nd to 3rd, bike went into false neutral (nothing new, happens intermittently), revs up to 10k (that doesn't happen often, if ever), loud knocking/tapping noise coming from 4th cylinder (seems to come from top-end, valve area), tapping was synchronized with rpms (higher rpm, greater frequency of taps/knocks), tapping continues at idle.
Immediately stopped running the bike, got it on a trailer, it is sitting.
What I've checked: I pulled off the valve adjustment covers for cylinder 4 and 3, looked around (it was dark) for any noticeable damage, missing nuts, broken valve adjustment screws -- I did not find anything. Specs of the intake valve for cylinder 4 were .002 ish, around .0025 and .002. I could not check the exhaust valve because I can't find my .003 feeler gauge. It was also dark out, had little time to spare, and did not check all valves for clearance specs.
Questions: What should I do first? I am planning on rebuilding the engine this winter, but I would like to keep riding into November.
Do valve adjustment, cam chain adjustment to see if that solves the problem?
Side info that may be in relation to this problem: I lately have been pushing this bike hard now that I solved my hesitation problems. Friends of mine say I will kill the bike pushing it to red line as often as I do. I will push the bike to its maximum speed at times too (110 with lack of compression).
Cylinder 1 has 90psi, cylinder 4 has 110 (last I checked roughly 1 month ago)
There is a continuing back fire at idle, and on deacceleration (possible a leaking valve seal? possible I have blown the seal finally?)
