Author Topic: Fun with an ARD mag.  (Read 1405 times)
« on: October 17, 2021, 04:41:49 PM »
   I missed the timing the first try and knocked a couple teeth off of the intermediate gear on the starter. 24V spins it like a mixer. I used the paint marks on the mag rotor and found TDC on #1 with a piston stop. I called it a night when I realized I had reversed the firing order rotation when I walked to the opposite side of the engine.  The wires are correct now but I didn't confirm #1 except from memory. I'll take it back off and confirm it tomorrow.
 It is throwing a spark now for sure, it's just a matter of timing. #2 carb is leaking too dagnabit.
« Last Edit: October 18, 2021, 08:10:44 PM by Don R »
Re: Fun with an ARD mag.
« Reply #1 on: October 19, 2021, 02:29:53 PM »
 I updated the drag bike project thread so I don't have to bore you guys with multiple examples of how dumb I can be.
« Reply #2 on: October 22, 2021, 07:31:37 PM »
 I just read 15 or so pages on the ARD and never did see instructions for an old style ARD/FM mag. I have the printed pages for a late type and they are different.  I'm still unsure the lower drive is all there, two tiny set screws are all that hold the pulley on the shaft?
 I see it as a failure as a product with no built in timing wheel in the drive or usable precise timing marks. I've marked my cutdown flywheel and drilled a dyno cover. Am getting close but what a pain.
« Last Edit: October 22, 2021, 07:34:41 PM by Don R »
« Reply #3 on: October 22, 2021, 08:16:09 PM »
Your definition of what's fun is different than mine...
Offline Medyo Bastos
  • Gusto mo titi ko?
    • project
« Last Edit: October 23, 2021, 04:18:29 AM by Medyo Bastos »
« Reply #5 on: October 23, 2021, 09:15:54 AM »
Thank you for those , I printed them. It's a lot less info than the newer type. My biggest question is the preset at 35* part, the only marks on mine are ones I made myself which seem to be suspect. I'm not racing this beast but it would be awesome to start it at a few car/bike shows and ride it once in a while.
  I used to think I was reasonably intelligent and knew a few things about magnetos and engines but this beast fools and frustrates me all of the time. I think an exorcist or medicine man might be called for.  I'd burn some sage but the leaking gas might light up.
  All that said, I predict it will run today.  I believe the current timing is closer to 45* so I'll back it off a top tooth before trying again. With 24 volts the mag will light up the timing light, I just need to do the math on the diameter and degrees on what's left of the flywheel/starting clutch.
 I marked TDC on the flywheel and using a bit of math marked it approx. 30* advanced. I got the timing light to light directly on the advance mark. Thanks for the help Medyo.
« Last Edit: October 23, 2021, 03:22:56 PM by Don R »
« Reply #6 on: October 24, 2021, 11:28:59 AM »
 My old school timing mark. (No usable dyno covers were harmed to make this part) Extreme lightening on flywheel, when I got there was no rotor.
