Author Topic: cb400f rear hub noise  (Read 825 times)
Offline hawaiikid
  • 1975cb400f
« on: October 18, 2021, 02:41:56 AM »
I Have a clicking noise that appears to be coming from my rear hub. It can be felt in my footpegs as well and increases with speed. I am thinking it is due to old worn cush rear wheel dampers; the ones that hold the four sprocket studs. the replacement part shows as 41241-286-000. wondering if anyone has an idea if that is what is causing the noise and if they know a good place to source (4) replacements. I understand they are a pain to remove and would like to hear any and all tricks to remove them. I hope to attempt the replacement without removing my newly mounted tire/tube. I installed new bearings about 350 miles ago, the brake pads are older. When trying to duplicate/troubleshoot with bike on centerstand I cant hear the clicking noise at all. If anyone has experienced this issue and can share the remedy it would help out.
Re: cb400f rear hub noise
« Reply #1 on: October 18, 2021, 03:23:51 AM »
Loosen the axle to provide room to carefully inspect every link of your chain. I think you might have a chain issue.
Offline newday777
« Reply #2 on: October 18, 2021, 04:41:32 AM »
Yup a dirty chain can give this. Give your chain a good cleaning and fresh lube if you haven't done this yet.
Cush bumpers are not hard to replace. You definitely don't remove the tire and tube from the rim to change the bumpers..... Where did you get that idea from hawaiikid?
Just remove the wheel from the bike, remove brake assembly and pull the sprocket drive assembly by pulling out from the cush rubbers then push the rubbers out from the brake side(mushroom tits hold them in place). Little rub of lube on the new tits, push in the holes and gently pull in place with needlenose pliers.
Stu
My current rides
Prior bikes....
Offline hawaiikid
  • 1975cb400f
« Reply #3 on: October 18, 2021, 08:04:52 PM »
i think i meant to say the worn out bush rear wheel damper is the culprit making the noise. part no. 41241-286-000. not sur though> sprockets and chain only have 350 miles on them and are well lubed/cleaned.
