Author Topic: CL350 - New points or convert to electronic IG????  (Read 870 times)
Offline andrewmundy
« on: October 18, 2021, 03:30:59 PM »
The timing on my cl350 is off. The points are ancient and if I'm going to adjust them I might as well get some nice ones. OR should I just go electronic ignition route. Whatre your thoughts?
Thanks,
Andrew
74 Honda CB550f
72 Honda CL350
Re: CL350 - New points or convert to electronic IG????
« Reply #1 on: October 18, 2021, 05:52:13 PM »
I hate the expense and failure rate of electronic, those are probably original points and have lasted years so replace with original
Offline grcamna2
« Reply #2 on: October 18, 2021, 06:28:33 PM »
The HondaMan electronic ignition box working in conjunction with points is excellent.
Offline robvangulik
  • Honda Fourever
« Reply #3 on: October 19, 2021, 02:27:54 AM »
I've been using Accent electronic ignition for some 20 years on 2 bikes, quite cheap, easy to install and really set and forget.
Offline grcamna2
« Reply #4 on: October 19, 2021, 03:26:27 PM »
Does it use OEM factory advance weights ?
Offline 2wheels
« Reply #5 on: October 20, 2021, 10:49:55 AM »
Nice bike Andrew.  My first bike was a 1972 CL350 only red.
The stock point system works fine on this bike.  Keep it stock.
Put new points in if you can get them from Honda.
1970 CB750 K0 (I can't believe I tossed my duck tail seat in the trash 30 years ago)
« Reply #6 on: October 21, 2021, 08:35:06 AM »
Every one of us will have an opinion!   I havent had an issue with points so I would go that route, but don't buy cheap ass aftermarket points!  You will regret that.
