Author Topic: CB350F Brake rod  (Read 550 times)
Offline brianc
CB350F Brake rod
« on: November 04, 2021, 06:46:08 PM »
Would one of you good people be able to supply me with the overall length of a 72 CB350F rear brake rod? From the centre of the clevis to the end. The rod on this project is a made up job, but it doesn't seem to be the right length, apart from the bends and stuff in it! I could find something on fleabay i suppose, but I need to know if any of the bits I have are close to the right ones anyway. Thanks
Offline Flyin900
Re: CB350F Brake rod
« Reply #1 on: November 04, 2021, 07:44:28 PM »
From the centre of the clevis pin to the end of the threaded rod is 530mm. No bends in a proper rear brake rod, it should be straight back from the metal bracket that carries the clevis pin.
1978 CB550K - Super Sport
1982 CM450A - Hondamatic
1982 CB900C - Custom
1983 CX650E - Eurosport
Offline brianc
« Reply #2 on: November 05, 2021, 12:42:24 AM »
Thanks for that, appreciated.
