Author Topic: Shipping US->EU of HM341 exhaust  (Read 1325 times)
Offline Teddyhoeg1982
« on: December 05, 2021, 08:24:12 AM »
There is a guy from US offering a set of moderately rusty original CB750K HM341 4-4 exhaust.
Shipping dimensions are 54”x24”x14” and it would be 35lbs.
Any advice what would be a reasonably priced carrier? Any experience? From first inquiry USPS Seem to charge 1500$….   :-X
Offline chiefum
Re: Shipping US->EU of HM341 exhaust
« Reply #1 on: December 05, 2021, 08:45:17 AM »
I would look into DHL, if it's available in the both of your locations.
Offline beemerbum
« Reply #2 on: December 05, 2021, 08:46:53 AM »
DO NOT use USPS for international shipping! They suck
« Reply #3 on: December 05, 2021, 09:57:51 AM »
 I bought a set from CMSNL, shipped to the us, I don't think they charged the full amount but don't have the receipt handy.
« Reply #4 on: December 05, 2021, 11:14:58 AM »
If you can buy a new set from CMSNL Netherlands shipping will be much lower.
Then you have https://www.davidsilverspares.co.uk/
Their max shipping cost was £20 before. Outside EU so customs  will be added.
CMSNL say they have lowered shipping costs.
« Last Edit: December 06, 2021, 03:02:10 AM by PeWe »
« Reply #5 on: December 05, 2021, 12:12:51 PM »
 I've been monitoring 4-4's unless someone listed some this weekend there aren't any. Busso was making noises about a run of Honda pipes but they aren't good about sharing information.
Offline Tim2005
« Reply #6 on: December 05, 2021, 02:21:49 PM »
Whichever carrier you use, don't forget that UK import tax charges are calculated based on the total price including shipping.
« Reply #7 on: December 06, 2021, 03:09:24 AM »
Buy now, they have in stock. !!!! ;D
Hopefully the better no numbers since I searched on K1. Much better than HM341.
They look right, HM341 had a strange dent in pipe beside brake pedal.
Put a banana in each pipe if you need same flow as HM341 ;D ;D
https://www.davidsilverspares.co.uk/CB750K1-FOUR-1971/part_217723/
You need the heat shields and mounting set too. Plus long bolts, clamps snd maybe spigots too.
But all the extra slways available. Pipes the vital stuff!!
« Last Edit: December 06, 2021, 03:12:39 AM by PeWe »
Offline 38rudge
« Reply #8 on: December 06, 2021, 06:52:04 AM »
These also have the dent to clear the brake pedal which is its purpose.
Offline 38rudge
« Reply #9 on: December 06, 2021, 07:24:00 AM »
These also have the 'dent' to clear the brake pedal, which is the reason it's there.
I take it that as HM340's that they do not have any baffles, apart from the removable end one?
« Reply #10 on: December 06, 2021, 07:24:00 AM »
Strange, I thought HM300 style since it was to a 71.
Maybe the restrictive HM341 then? A photo of the rear with diffuser/baffle beside should clarify.
Offline 38rudge
« Reply #11 on: December 06, 2021, 07:34:28 AM »
You are right, I meant HM300's but somehow generated another model by putting a 4 instead of a 0. My mistake.
Offline 38rudge
« Reply #12 on: December 06, 2021, 07:38:46 AM »
What is the difference between the HM300's and the Lotus Roots ones?
Offline 69cb750
« Reply #13 on: December 06, 2021, 07:49:37 AM »
HM300  removable baffle is smaller,  baffles inside pipe.
Lotus roots, removable baffle is larger, no baffle inside pipe.
Offline 38rudge
« Reply #14 on: December 06, 2021, 08:34:53 AM »
Are the DS and Yamiya HM300's both made buy the same company and are the DS ones likely to be imported Yamiya ones?
Can't see that there would be two separate companies making the exhausts? Yamiya always have good reports as to their quality and fit and finish of their products do DS have the same reputation for their parts?
Offline beemerbum
« Reply #15 on: December 06, 2021, 08:41:31 AM »
I have ordered, received and installed two sets of HM 300 repro pipes from DSS, Both boxes were labeled Tamiya
« Reply #16 on: December 06, 2021, 09:44:42 AM »
Lotus Root pipes are very hollow inside ;)
Not much in there ;D
Here photos of my Yamiya No numbers and Lotus Root also from Yamiya when new.
Diffusers compared. The No numbers have also padding around that I have removed. Search for HM300 diffusers on eBay or where ver they are sold and you will see.
Lotus Root model look like bombs (with same look when mounted) ;D
« Last Edit: December 07, 2021, 12:42:54 AM by PeWe »
