Author Topic: cb400f - Rotor/Flywheel puller bolt size  (Read 1754 times)
lohebohi
« on: March 01, 2007, 03:09:51 pm »
Does anyone know the thread size and pitch for the Rotor/Flywheel on a cb400f specifically?
edit: The thread size is M18x1.50.  I purchased a bolt for $5 at a local Metric Fastener speacialty store and it fits.  The oil filter bolt and rear axle bolt are not the same size.
note: for those who might not know, I recently learned that the Rotor for the 'alternator' in these bikes serves as a flywheel for the engine.
« Last Edit: March 02, 2007, 10:26:48 am by lohebohi »
Offline malcolmgb
  • What am I not? an
  • The BEST 400 four by far
    • malcnet
Re: cb400f - Rotor/Flywheel puller bolt size
« Reply #1 on: March 16, 2008, 12:36:56 pm »
can anyone confirm this is the correct size of bolt please I have seen somewhere else listed as M16, is there any particular length required too. Will a normal bolt be ok or should I go for one of the hardened special tools sold.
Malcolm
1977 CB400F
1973 CL175 K7
1976 XL175 - Sold
1964 CL72
1966 CA78
Offline mca2
« Reply #2 on: January 19, 2011, 02:19:02 pm »
I've also looked around quite abit, and i'm also interested to know what the threadsize is.
Looking for a NOS CB400f2 tank in parakeet yellow!
Offline fmctm1sw
« Reply #3 on: January 19, 2011, 07:21:37 pm »
I think the 350F and 400F were the same.  That said, I believe a 16 is going to be too small.  The 350F/400F and 550K are definitely different.  The 550 is smaller.  I have a "real flywheel puller" that I got from Z1 I think and a bolt I got from the local hardware store for the 550.  I'd bet the 350F is 17 or 18 and probably 17.  It's only one size bigger than the bolt I bought for the 550.
Quote from: 754
Quote from: inkscars
This is not a pod thread
1973 CB350F
1973 CB350G
1975 CB550K
1983 GL650I
1994 Honda TRX300
1999 Honda TRX250
Offline Bowswell
  • CB750K1,CB750 K4,CB350F,CB400t1,meanstreak
« Reply #4 on: January 20, 2011, 03:05:59 pm »
18mm ::)
