Author Topic: Honda Z50  (Read 3294 times)
Offline BenelliSEI
  • 1969 cb750
Re: Honda Z50
« Reply #25 on: January 10, 2022, 01:12:26 PM »
The  chain case/ flywheel cover was missing a section, inside. Looks like a broken drive chain must have “bunched and chunked” it’s way through. The ignition components under the flywheel were covered in lube and dirt  Cut a small piece of alloy, two rivets and a bit off JBWeld. Should keep it cleaner. Not a show piece, for sure. Can’t believe I’m wasting time on this, instead of digging into the Sandcast or the Rickman. It is fun to work on something different. Installed new points and condenser before the flywheel. Grand kids are coming to downhill ski this weekend. Like to show them my progress. My son (and his son) completely stripped the older bike. Frame etc., are off for powder coating. It’s getting a full resto.
Interestingly, these early Z50 have no mechanical ignition advance. Set to the advance mark, and that’s it. Fine adjustments are made using a timing light, and adjusting the points gap. Strange?
« Last Edit: January 10, 2022, 05:35:29 PM by BenelliSEI »
Offline BenelliSEI
  • 1969 cb750
Re: Honda Z50
« Reply #26 on: January 11, 2022, 05:59:08 PM »
Good progress today. No photos, the shop was so cool the battery in my IPad went away! Repaired the exhaust system and blew some paint on it too. Kids are coming for a ski day this weekend so hope to have something to show them!
Offline BenelliSEI
  • 1969 cb750
Re: Honda Z50
« Reply #27 on: January 12, 2022, 01:30:02 PM »
A bit more today. Need to install the foot peg crossbar and then may have to fire it up! Small package but still lots of little jobs.....
« Last Edit: January 12, 2022, 01:34:21 PM by BenelliSEI »
Re: Honda Z50
« Reply #28 on: January 12, 2022, 03:11:14 PM »
Looking good John. Is your son going to do a repaint on this one sometime? Or, leave it original?
Offline BenelliSEI
  • 1969 cb750
Re: Honda Z50
« Reply #29 on: January 12, 2022, 04:10:17 PM »
This tank actually has a pretty “porous” base plate. I closed it up with JB Weld and will probably line it, with a CASWELL product.
Hope to find a used headlamp and leave it “as is”. I kind of like it this way and no one has to worry about dropping it occasionally (which has happened more than a few times!).
« Last Edit: January 12, 2022, 06:06:32 PM by BenelliSEI »
Offline BenelliSEI
  • 1969 cb750
Re: Honda Z50
« Reply #30 on: January 16, 2022, 05:27:41 PM »
Ran the “freshened” motor today. It fired instantly and settled down immediately to a nice, super smooth, quiet idle. Checked ignition timing and it was so close to spot on, I’m not touching the points gap! Clicked through all three gears and found neutral easily. Starts first kick, when warm. It can cool down over night and I’ll re torque the top end tomorrow.
On a hunch, I started up on the original carb that was on the older Z50. I’m sure this one came with a Chinese knockoff carb. I never got it to run well (last Fall when Chris dragged this thing here). Next test will be to see if I can make it work now. If not, straight in the bin and we’ll be looking for NOS.
Scrubbed the chain and final coated the foot pegs. I want this thing off the table so I can get back on the S/C Project.
Re: Honda Z50
« Reply #31 on: January 16, 2022, 06:14:47 PM »
Congratulations John, satisfying to have all the planets align well like that...
DrATV has good quality carbs, picked up one for my C70 and other than a small bit of tuning it ran well out of the box. In case you cannot find a good OEM one ...
Offline BenelliSEI
  • 1969 cb750
Re: Honda Z50
« Reply #32 on: January 17, 2022, 05:27:06 AM »
Thanks. I’m pretty sure I’ll be needing one. First real blizzard of the Winter today. May be a while before I can find the shop.
« Last Edit: January 17, 2022, 08:11:07 AM by BenelliSEI »
Offline MauiK3
  • A K3 is saved
  • Old guy
Re: Honda Z50
« Reply #33 on: January 17, 2022, 07:13:01 AM »
Did the steering stop get broken? Tank is dented like it was.
Great little bike, looks good.
1973 CB 750 K3
10/72 build Z1 Kawasaki
Offline BenelliSEI
  • 1969 cb750
Re: Honda Z50
« Reply #34 on: January 17, 2022, 08:14:20 AM »
Good spot! Every one of them has the stop broken off..... it’s a small lug, welded to the bottom of the steering stem bearing tube. The welded portion stays attached, but the lug snaps off where it is unsupported. Working on a different solution.
Re: Honda Z50
« Reply #35 on: January 17, 2022, 08:50:29 AM »
Make it from black box metal, they are indestructible...
That's a joke if you didn't realize...
Got a photo of it? I am having trouble visualizing it.
Offline BenelliSEI
  • 1969 cb750
Re: Honda Z50
« Reply #36 on: January 18, 2022, 04:14:18 PM »
Will take a photo later. It’s basically a small, rectangle shaped tab, welded (facing down) on the back side of the headstock bearing frame tube. The bottom plate of the tree has a notch cut in it, that the tab sits inside. Unfortunately, the constant knocking eventually snaps off the tab..... then the top of he tree hits th tank. VERY common failure.
Offline BenelliSEI
  • 1969 cb750
Re: Honda Z50
« Reply #37 on: January 19, 2022, 12:32:08 PM »
Ready to ride! Next I have to rebuild the motor for the earlier one!
Offline BenelliSEI
  • 1969 cb750
Re: Honda Z50
« Reply #38 on: January 19, 2022, 12:36:34 PM »
As an aside: swapped back the “Chinese” repro carb and the damn thing ran even better...... not touching it again!
Re: Honda Z50
« Reply #39 on: January 19, 2022, 01:09:16 PM »
Hard to believe but great!   Will that little bike be a "snow rider"?
Offline 34barab
Re: Honda Z50
« Reply #40 on: January 19, 2022, 01:34:02 PM »
That is one hot little ride!
Current Projects: 1973 CB750K3; 1972 CB350K4; 1980 CX500D;1969 CB750.  Roadworthy: 1971 CB750K1
Offline MauiK3
  • A K3 is saved
  • Old guy
Re: Honda Z50
« Reply #41 on: January 19, 2022, 01:41:13 PM »
Very, very cool.
I want one!
1973 CB 750 K3
Offline BenelliSEI
  • 1969 cb750
Re: Honda Z50
« Reply #42 on: January 19, 2022, 05:50:10 PM »
“Snow Submarine!”...... it’s deep enough here this bike would disappear.
Offline BenelliSEI
  • 1969 cb750
Re: Honda Z50
« Reply #43 on: January 19, 2022, 05:54:52 PM »
Thanks guys. My grandson was pretty excited when he saw the pictures. He and my son are “restoring” the older Z50. They both reminded me I promised to freshen that engine too.
I don’t rememberer my Dad (or grandfather) ever taking an interest in any of my projects!
Re: Honda Z50
« Reply #44 on: January 19, 2022, 06:23:49 PM »
Crazy the carb ran better when reinstalled...might have had an air leak...or something was hung up that freed up by the R&R...I wouldn't touch it either!
Bike looks great! I agree with Son and Grandson's assessment!
Hopefully you can teach the grandson how to wrench on motors and bikes sometime and how to properly maintain a bike. Would be a good idea to make them do the walk-around, pre-ride inspection, checking air and fluid levels, etc. before every ride now to instill in them the discipline required and ingrain the behavior.
