Author Topic: CB750 F2 ‘77 PD41B Slide Assembly Link Spring  (Read 387 times)
Offline zalion0
« on: December 14, 2021, 07:47:13 AM »
I’ve been troubleshooting with my PD41B carbs  (poor idle with no choke and engine dying when initially opening throttle) and was reviewing my carbs again. I have noticed however that carb 2 appears to be missing the slide assembly link spring as shown in the attached. Should carb 2 have an assembly link spring (only as I’m convinced it’s missing) and if having no spring would cause any issues.?
« Last Edit: December 14, 2021, 07:51:49 AM by zalion0 »
Offline 69cb750
Re: CB750 F2 ‘77 PD41B Slide Assembly Link Spring
« Reply #1 on: December 14, 2021, 12:15:10 PM »
Buy a spring.
Offline zalion0
« Reply #2 on: December 14, 2021, 12:30:49 PM »
Ones in order. Do you know what function the spring performs? My research so far has drawn a blank.
« Reply #3 on: December 14, 2021, 03:51:17 PM »
Good question.  I think it holds the link in place but it's been a while since I messed with a PD carb.
