Author Topic: ARD part numbers  (Read 2333 times)
Offline Jim F
  • go baby go
ARD part numbers
« on: March 01, 2007, 08:36:25 PM »
for all that has the ARD ignition systems with points
I think there are only 3 of us..........:) Rich, Terry and my self
and I already sent them e-mails of this but for everyone else
enjoy and I hope this helps
Hey guys
Just got the break down on the invoice from bill Lopoulos Magneto parts
Here are the part numbers for the Fairbanks mores system
Coil        A2477C
Condenser       SXY2433
Rotor        M2765
Gasket set            GK17
Points             A2437A
Cap               G800
Everything but the points was replaced and the bearings where re-packed
This type of mag has the single ball type bearings or 3 piece type bearings
you have a inter/outer race with a cage system to hold the bearings
the magnets where checked and are in really good shape
As far as the type of mag system, He said he has never seen one like this
but thought it was originally for a Wisconsin engine of some type but said
it was
a very rare type. He doesn't have the housings that he thought he did. His
suggestion as far as timing was to run about 35 degrees
of advance and that should help with starting and run fine up top
all this plus labor was $175.00 US
Jim
2002 RC51 1000 (SP2)
1983 GS1100EC Suzuki
1992 KTM500 2 stroke
1975 CB750/836 Honda
1978 GS750/840 Suzuki
Offline puppytrax
Re: ARD part numbers
« Reply #1 on: March 02, 2007, 03:51:06 PM »
As mentioned in the other long thread, Joe Hunt has the CNC machined housings that use the FM internals -
http://www.huntmagnetos.com/motorstore.php
MAGNETO PARTS & ACCESSORIES     100     BILLET ALUMINUM HOUSING     $178.00
Steve Belanger at MainelyMagnetos.com did my ARD/FM mag rebuild; just got off the phone with him, mine ran $160. Steve said he may be able to find some housings; he thinks the old base-mount mags used the same mounting bolt pattern ARD used.
I requested a parts breakdown; hopefully it will match what Bill gave Jim...   ;D
Steve is going to try to build up an ARD mag "clone" for me...using all new parts...  ::)
...stock 1972 CB500 '500 Four' undergoing re-assembly...
...Stock 1972 CL450 'Scrambler' also being re-assembled...
Offline the B.N.G.
    • made cheap
« Reply #2 on: October 22, 2010, 10:15:24 AM »
Jim,
Thanks for the old info.  I am running an ARD setup on my CB750 and the info was great.
I'm the Black Nutz Gangsta, the B.N.G.!
Offline Jim F
  • go baby go
« Reply #3 on: October 22, 2010, 10:39:11 AM »
Glad to help
I was surprised to see this old thread pop up from the grave
enjoy
Jim
« Reply #4 on: October 22, 2010, 09:27:40 PM »
 I have an, as pulled 4 cylinder FM mag off an International.
 That may work..
 I have a FM, ready to go on a custom built plate and drive for a 750
 In my hands right now I have a NOS WICO top for a 4 cyl mag, so there is another  possiblity..
 The Hunt custom BILLET housing sounds tasty, wish they would re-introduce their old 754 drive cover..
Offline Big Jay
    • CBRzone
« Reply #5 on: October 23, 2010, 09:07:02 PM »
I was under the impression that the points type mag was a Fairbanks Morse from a Ford tractor. ARD only made the drive.
