Author Topic: New throttle cables?  (Read 701 times)
Offline Kevin D
  • SE Michigan
« on: December 24, 2021, 07:58:51 AM »
This off season, I’m trying to replace old parts on my CB that might put me on the side of the road.
I’m happy to say this bike has been utterly reliable.
My throttle cables are 50 years old, as is just about everything else on this CB. They have not given me any trouble at all, and they may be higher quality than any replacement cables.
I have read that the return cable also works as a pull cable.
Inspect/lube and good for another 50 years?
The clutch cable was replaced about 5 years ago. I had roughed up the old cable removing it, but the old cable is still adequate for emergency use.
 Yamiya newsletter arrived today with a new item, carb needles, recommended for 836cc.
71 CB750 K1
104,000 miles
Original Owner
———past———
70 SL100/125/150
70 Candy BlueGreen CB 750 K0
Re: New throttle cables?
« Reply #1 on: December 24, 2021, 09:35:15 AM »
Hey Kevin...that is so true, I had an aftermarket throttle cable fail on my '74 Kawasaki, it was less than two years old.
Have you searched for Honda OEM cables yet?  There may be some out there?
Just an example here, doesnt really look like NOS.
https://www.ebay.com/itm/173883695598?epid=1150240787&hash=item287c46a1ee:g:T1gAAOSww9BcwT9H
Offline Kevin D
  • SE Michigan
« Reply #2 on: December 24, 2021, 05:59:13 PM »
Yes, both Yamiya and David Silver have Honda cables, and they are twice the price of aftermarket. Yamiya has a
3-pack, both throttle cables and a clutch cable aftermarket $45, and a hefty shipping charge on top of that.
I don’t know if the JMarks Honda parts store is still operating?
If I replace every part that’s old, before long I will have a new motorcycle. I’m just trying to figure out which old parts might be tired and ready to be retired. Maybe just stick to tires brakes points plugs.
71 CB750 K1
104,000 miles
Original Owner
———past———
70 SL100/125/150
« Reply #3 on: December 24, 2021, 06:41:58 PM »
Kevin, in my experience, all cable failures happen at the ends.  Closely inspect your controls and the mechanisms at the far end for poor adjustment, rubbing, chafeing, pinching or any fraying or unraveling of the wire.  9 out of 10 times, a cable fails where it meets the barrel at the end.  Make these inspections part of routine maintenance.  Once any sign of damage is found, that cable is living on borrowed time.
« Reply #4 on: December 24, 2021, 07:23:31 PM »
JMarks business is closed after his death... unfortunately...
« Reply #5 on: December 24, 2021, 08:20:39 PM »
 I asked a question about carb needles recently, those needles may be the answer to it. In my case I had gone from a long muffler 4-1 on a ported/cammed/836 back to 4-4 no no.'s. I hadn't considered the need for a re-think on the needle position and jets. When I did, I looked at a lot of different model needles, they all appeared to be the same.
Offline stocky
« Reply #6 on: December 24, 2021, 08:58:15 PM »
Recently was stranded because of an aftermarket throttle cable that snapped only after about a year's worth of use. Luckily I was at a gas station nearby home went back to grab my old OEM cable that I replaced when I was rebuilding the bike thinking it'd be better and safer to use a new one...wrong! Not only did I get the bike home, it fixed a really stiff throttle issue that I thought was normal, the OEM cable throttle operation was SO much smoother.
« Reply #7 on: December 24, 2021, 10:18:19 PM »
Honda cables really are worth the extra few dollars as the liner they use is far superior and they do not require nor should they be lubed with traditional cable lubes…
Offline Kevin D
  • SE Michigan
« Reply #8 on: December 25, 2021, 09:03:22 AM »
I have ridden my sons Hornet a bit and the throttle response is immediate and exaggerated, nothing like my CB. After a while on the Hornet I was longing for the CB and the 50 year old cables and carbs, stretched out and slack, controllable, modulated. My CB doesn’t go tearing down the road unless you intend for it to. I adjusted the slack out a bit on the pull cable adjuster below the master cylinder, but it started me thinking that a new pull cable will turn my 50 yr old CB into a kitted FI Hornet, haha. Also thinking the 50 year old cable is very tired.
 So I will give it a once over and maybe a new Honda pull cable.
Merry Christmas to all🧑‍🎄
71 CB750 K1
104,000 miles
Original Owner
———past———
70 SL100/125/150
« Reply #9 on: December 28, 2021, 11:04:11 AM »
His eBay page states they will be back 1/14/22...
https://www.ebay.com/str/josephfmarksmotorcycleparts
