Author Topic: Cb500 "winker" issues  (Read 495 times)
Offline sadolfson
« on: December 25, 2021, 08:46:38 AM »
I have the whole bike wired up and all the lights work but I cannot get the signals to flash. There are three wires leading to the winker: grey black and green. The wiring diagram shows the black and grey connected to a 2 prong winker and the green loose. The bike had a 3 pole winker when I got it and I don't know if it worked then because the bike was disassembled. The winker has three poles labelled L, BI+, and -IE. I don't know which goes where. Can anyone help? One other thing, the left hand switch has 1 orange, 1 light blue, 1 light green, and 2 grey wires going to the headlight case. I've connected everything but the second gray wire which doesn't show up on the wiring diagram. Could that be the problem? I have good continuity to the 3 wires at the winker location. The LH switch looks like it is stock? The lights all work and but the blinkers don't blink. I do not have any LED bulbs. I have a brand new 3 prong and a new 2 prong winker that work with a test light and fully charges battery.
Offline minimo
  • 1977 CB550F 1975 CB400F 1959 Ducati 200 Americano
Re: Cb500 "winker" issues
« Reply #1 on: December 25, 2021, 08:49:55 AM »
Run the loose green to a clean ground and you should be good.
Offline sadolfson
« Reply #2 on: December 25, 2021, 09:01:07 AM »
I will try that. So does the grey wire go to the + or the - on the 2 pronged winker?
Offline sadolfson
« Reply #3 on: December 25, 2021, 09:04:02 AM »
Or does it even make a difference?
« Reply #4 on: December 25, 2021, 09:07:15 AM »
Winkers frequently dont flash unless the engine is running, use the 2 prong unit and leave the green wire loose it does not need to be grounded.
On the lh switch there should not be 2 greys leads, the grey in the loom needs to connect to the grey into the switch that goes to winker switch, light blue and orange are out puts from switch to appropriate side of bike for winkers, light green is horn
Offline minimo
« Reply #5 on: December 25, 2021, 09:19:57 AM »
Try flipping the Black and Grey wires.
Offline minimo
« Reply #6 on: December 25, 2021, 09:22:00 AM »
Black is power into the flasher and Grey is power out to the left bar switch for the turn signals.
« Reply #7 on: December 26, 2021, 12:37:20 PM »
Maybe this chart can help?
