Author Topic: '71 CB500 K0 garage find, now ongoing project  (Read 1377 times)
Offline chickenman_26
    • Motorcycle Consumer News
« on: January 22, 2022, 09:32:22 AM »
First, thanks to those who nominated this bike for BOM. I never expected to win anything with the bike, so the pics I took during the resurrection were mainly to help me put it back together correctly. Because I ride everything I own, I'm more into keeping my bikes bone stock with maybe a few comfort/convenience mods. Also, I'm a lot older than the bike and remember them in the showroom, so keeping it as close as possible to that look is a trip down memory lane for me - as if I still had a working memory.  ;)  Click the pics for a bigger view. Click twice for zoom.
I found the bike on CL with a price of $2500. No ignition switch, didn't run and hadn't for years. The owner told me he was moving and if it didn't sell on CL. it'd be at his garage sale the next month. $600 later, I loaded it in my truck and "Honey, look what followed me home!" My wife is a terrible enabler and is responsible for this happening dozens of times over the years - a high class problem  :D
First order of business was to find out why #1 had no compression and others were low - the engine had sat so long that some valves were stuck partially open, but luckily not enough to get bent as the owner attempted to kick it over. So, off comes the top end for inspection/clean/rebuild. The whole top end had been glued together with some type of hard setting Permatex, I suppose to stop up a bunch of leaks. It got all new gaskets, seals and rings. The skirt to cylinder clearance, skirt, and bore measured well within specs in the shop manual, so I lightly decked the block and honed the bores using a Brush Research ball hone (dingleberry hone).
More to come....
« Last Edit: January 23, 2022, 10:15:50 AM by chickenman_26 »
MCN DTF
Re: '71 CB500 K0 garage find, now ongoing project
« Reply #1 on: January 22, 2022, 04:56:57 PM »
 A garage find is way better than a barn find, fence row find or leaned against a clothesline pole find. I have had all of the above.  My wife finds ads for bikes and shows me but for some reason isn't always thrilled when I bring a couple home. Maybe 12 is too many?
Offline newday777
« Reply #2 on: January 23, 2022, 02:58:35 AM »
Well chickenman the pictures don't show up....
Stu
My current rides
Prior bikes....
Offline MauiK3
  • A K3 is saved
  • Old guy
« Reply #3 on: January 23, 2022, 06:56:27 AM »
no pictures
1973 CB 750 K3
10/72 build Z1 Kawasaki
« Reply #4 on: January 23, 2022, 09:26:27 AM »
no pictures
Right. I'll get it fixed. Thanks
MCN DTF
« Reply #5 on: January 23, 2022, 10:21:43 AM »
LOL. I once brought home a CL350 with a small tree growing through the frame. "Ran when parked." :o
MCN DTF
« Reply #6 on: January 23, 2022, 09:19:14 PM »
They need to autocorrect all those ads claiming ran when parked to say ran until parked, might be true for some of them...
« Reply #7 on: February 07, 2022, 08:39:23 AM »
This was my wife's fault - I swear it. She said "if you don't click buy it now, I will." The bike got a new OEM exhaust several years ago, so what the heck?  You can't take it with you, eh?
Stu
« Last Edit: February 17, 2022, 12:57:30 PM by chickenman_26 »
MCN DTF
« Reply #8 on: February 07, 2022, 08:41:26 AM »
Gorgeous...you dont come across those every day!  Congrats
Offline CB500K1
    • Restoration Honda CB500K1 1972
« Reply #9 on: February 12, 2022, 02:32:35 AM »
Nice bike and scoring that brand new tank is a killa !
I'm in the middle of a resto of a similar bike. I wondered what torque you used on the cam sprocket bolts and if you used locktite with them. Cheers
« Reply #10 on: February 13, 2022, 02:13:38 PM »
7 x 12 mm bolts. Spec torque is 10.1 to 10.8 Lb-ft (121 to 127 Lb-in). I used 120 Lb-in along with Loctite 243.
Stu O
MCN DTF
Offline dhall57
« Reply #11 on: February 13, 2022, 03:02:12 PM »
Beautiful tank Stu, nice find. I need to get busy restoring mine ;D
1970 CB750KO
1971 CB500KO-project bike
1973 CB350G- project bike
1974 CB750K4-project bike
1974 CB750K4
1976 CB750K6
1977 GL1000
1997 Harley Wideglide
« Reply #12 on: February 13, 2022, 08:02:05 PM »
Dwight,
PM me when you get a parts list together. I have a large Jap bike bone yard locally.
Stu O
MCN DTF
