Author Topic: Dewey’s CB750 K2  (Read 8222 times)
Offline SanDogDewey
Dewey’s CB750 K2
« on: January 23, 2022, 06:23:19 PM »
Just for reference a CB750 and 2 motors will fit in the back of a Toyota Tacoma.
And so it begins…
Re: Dewey’s CB750 K2
« Reply #1 on: January 24, 2022, 08:25:50 AM »
... a CB750 and 2 motors will fit in the back of a Toyota Tacoma.
Ha, good to know, I have a Tacoma.  You building a bike with two motors?!
Russ Collins did it!
Offline SanDogDewey
« Reply #2 on: January 25, 2022, 06:44:51 AM »
No, I think I’ll stick with one. I think it will corner better! Lol
Offline SanDogDewey
« Reply #3 on: January 27, 2022, 05:49:18 PM »
Got a lift today from HF. Should make things a bit easier. None of the local HF stores had a 1000 lb engine stand. They’re supposed to have some next month,
« Reply #4 on: January 30, 2022, 08:40:39 AM »
A flat platform style scissors jack is handy if you have room between the exhaust pipes to reach the frame rails.. allows you to pull the front end apart or without a center stand it can help you lift the rear end to pull wheel etc...
Offline SanDogDewey
« Reply #5 on: February 02, 2022, 06:18:43 PM »
Getting parts on order! This is my tracking system. I highlight the parts as I order them. I also write on the invoice what drawing the part belongs to so I know where the part goes.
Offline SanDogDewey
« Reply #6 on: February 02, 2022, 06:20:21 PM »
Forks are pretty rough but they didn’t leak! The tops are pretty pitted and rusty.
Offline SanDogDewey
« Reply #7 on: February 02, 2022, 06:21:35 PM »
Electrical is toast. This pin was welded to the socket. New harnesses ordered.
Offline SanDogDewey
« Reply #8 on: February 02, 2022, 06:38:51 PM »
Tires came today. I’ve got some work to do before these get mounted up. Front and rear hubs are getting replaced.
« Reply #9 on: February 03, 2022, 07:17:19 AM »
Wow, that is quite a system, good on you!
Continentals are great tires, have them on my Kawasaki, you will really like them
Offline kghost
« Reply #10 on: February 15, 2022, 04:21:38 AM »
Is that my old one?
If so...Here's what it looked like back in the day....
And yes...it needed an oil cooler in 100° South Texas summer heat.
Stranger in a strange land
Offline BenelliSEI
  • 1969 cb750
« Reply #11 on: February 15, 2022, 06:07:12 AM »
Clever..... good to have the space! Fork tops look rough, but usually come apart OK.
Offline MauiK3
  • A K3 is saved
  • Old guy
« Reply #12 on: February 15, 2022, 07:36:51 AM »
Nice tires, they are on my K3.
A pair of knockoffs are on my Z1
1973 CB 750 K3
10/72 build Z1 Kawasaki
Offline SanDogDewey
« Reply #13 on: February 15, 2022, 09:04:43 AM »
Quote from: BenelliSEI
Got them apart and new fork tubes have been received. Waiting on the seals now.
Offline SanDogDewey
« Reply #14 on: February 15, 2022, 09:07:16 AM »
Quote from: kghost
Is that my old one?
Yes, that’s the one.
« Reply #15 on: February 15, 2022, 12:55:06 PM »
 I put the Conti twins on the nugget. I'd like to say I like them but they are still wearing their nubs so I really don't know. They rode to the car wash, to the park for pics and back home. A couple miles, tops.
Offline kghost
« Reply #16 on: February 15, 2022, 05:12:18 PM »
Quote from: kghost
Is that my old one?
I'll see if I can drag out some more photos if you like...
Offline SanDogDewey
« Reply #17 on: February 20, 2022, 08:55:55 PM »
Started building up the bars and noticed the left switch was rotated more forward than the right. Bars are drilled wrong. Waiting on word from supplier. Do yourself a favor and spray a little silicon on the inside of the bars to make the wires slide through more easily.
Offline SanDogDewey
« Reply #18 on: February 20, 2022, 08:59:25 PM »
Quote from: kghost
…of the girl or the bike?
Offline SanDogDewey
« Reply #19 on: February 22, 2022, 06:07:45 PM »
Got the forks mostly rebuilt today. Bolted the lowers to the engine stand to resurface them. Worked out pretty well. There are still some small dents still in them as I didn’t want to sand the down any further. They didn’t leak, but the tops were heavily pitted. The piston (item 7 on parts breakdown) would spin freely on the old fork. It was tight getting the bottom snap ring on and it doesn’t spin now. Is this an issue?
« Last Edit: February 22, 2022, 06:09:19 PM by SanDogDewey »
Offline BenelliSEI
  • 1969 cb750
« Reply #20 on: February 22, 2022, 06:23:17 PM »
Mine tightened up the same way, should not be a problem. Is the “ ring” above it still able to spin and rattle in it’s space? I like the use of the stand! New master cylinder?
« Last Edit: February 22, 2022, 06:25:32 PM by BenelliSEI »
Offline SanDogDewey
« Reply #21 on: February 23, 2022, 07:38:26 AM »
Yes, the damper valve still spins freely. New master cylinder, the one on the bike had lost all the black anodizing.
The stand worked great, allows you to rotate them, but I got some streaking when I cleaned the fork lowers with AlumPrep 33. I’ll restrip, clean and scotch-brite them. My first time going for an original look. I’ve polished or powder coated everything on previous bikes.
« Last Edit: February 23, 2022, 07:39:57 AM by SanDogDewey »
« Reply #22 on: February 23, 2022, 05:03:16 PM »
I use these:
http://www.tcbroschoppers.com/honda-cb750-engine-stand.html
and now they cost $20 less than when I bought mine!
Offline SanDogDewey
Re: Dewey’s CB750 K2 - Gauge Paint
« Reply #23 on: March 14, 2022, 06:02:41 PM »
Got the gauges rebuilt today. Still need to paint the ends of the needles and the “blue” on the inner liner. What is a good color match for these two? Testors orange fluorescent paint?
Used new glass, housings, crimp rings, gaskets and face dials from Yamiya.
« Last Edit: March 14, 2022, 06:21:36 PM by SanDogDewey »
Offline SanDogDewey
« Reply #24 on: March 14, 2022, 06:06:28 PM »
Also got the front forks and handle bars assembled. I ended up using Super Bike bars from Yamiya.
