Author Topic: Dewey’s CB750 K2  (Read 8248 times)
Offline newday777
Re: Dewey’s CB750 K2
« Reply #100 on: September 14, 2023, 05:23:31 PM »
Stu
My current rides
Prior bikes....
Offline SanDogDewey
« Reply #101 on: September 14, 2023, 06:35:20 PM »
Motor is mostly in!
Offline SanDogDewey
« Reply #102 on: September 14, 2023, 06:37:53 PM »
Beautiful finish on the engine!
Yes it is! Thanks to you Mark.
« Last Edit: September 14, 2023, 09:21:26 PM by SanDogDewey »
Offline SanDogDewey
« Reply #103 on: September 16, 2023, 07:58:53 PM »
Got a few more thinks hooked up today. Need to get a battery and some fuel line. Got a handful of nuts and bolts coming from Partzilla.
Offline SanDogDewey
Re: Dewey’s CB750 K2 - Breather Hoses
« Reply #104 on: October 12, 2023, 08:35:44 AM »
Read all the threads about breather hoses. Just want to verify for my K2. The cylinder head cover and top nipple on the oil tank are vented to the atmosphere. Were they originally T’d together? What is the best way to route them? The bottom nipple on the oil tank (overflow?) is connected to the rear nipple on the crankcase.
Has anyone found suitable hoses at NAPA? I fitted a hose between the oil tank and crankcase, but need to find something that fits the cylinder head cover and top oil tank vent (~12mm). Also looking for fuel lines (5.5mm) and overflow lines (3.5mm) today.
« Last Edit: October 12, 2023, 08:40:53 AM by SanDogDewey »
Online denward17
« Reply #105 on: October 12, 2023, 09:18:14 AM »
Thread drift/ Is that valve cover polished or painted?
Looks great !
Offline SanDogDewey
« Reply #106 on: October 12, 2023, 09:24:41 AM »
Looks great !
Thank you! The valve cover is polished and clear coated.
Offline SanDogDewey
« Reply #107 on: October 13, 2023, 03:10:14 PM »
Got the rest of the engine hardware installed.
Offline SanDogDewey
Re: Dewey’s CB750 K2 - Replacement VIN Plate
« Reply #108 on: October 15, 2023, 02:29:50 PM »
The PO had the frame powder coated and the VIN tag was missing. I ordered a replacement and got it installed today. The rivets are about 1.8mm wide. A 1/16" drill bit is about 1.5, so it worked well. I formed the tag around a piece of pipe to get a curve in it. Recommend drilling the first hole and installing the rivet, then drill the second hole and install the second rivet.
Offline BenelliSEI
  • 1969 cb750
« Reply #109 on: October 15, 2023, 02:37:02 PM »
Super nice finishing touches! Nice attention to the details. I always feel those are the ones that complete the job. Well done.
« Reply #110 on: October 15, 2023, 02:43:29 PM »
Yep, that's just how mine looks. ;)
I get fuel line from Honda as it fits right and lasts long. However, for the fuel line there is a polyethylene type (I think from Motion Pro?) that is hard to get, but makes better fuel line if you have to remove/reinstall the tank very often.
« Last Edit: October 16, 2023, 07:04:49 PM by HondaMan »
« Reply #111 on: October 16, 2023, 01:32:19 AM »
Tygon? Like used on weed eaters and chain saws?
Tygon gets stiff due to UV if I recall correctly.
Offline SanDogDewey
« Reply #112 on: October 16, 2023, 08:47:25 AM »
I get fuel mine from Honda as it fits right and lasts long. However, for the fuel line there is a polyethylene type (I think from Motion Pro?) that is hard to get, but makes better fuel line if you have to remove/reinstall the tank very often.
I ordered fuel line and overflow lines from Honda. Thank you!
Offline SanDogDewey
Re: Dewey’s CB750 K2 - Fuel Line Routing
« Reply #113 on: October 16, 2023, 06:41:53 PM »
Fuel lines and clamp rings showed up today. Got them routed and installed.
« Last Edit: October 16, 2023, 07:00:59 PM by SanDogDewey »
Offline SanDogDewey
Re: Dewey’s CB750 K2 - Gas Tank Decal
« Reply #114 on: October 16, 2023, 06:45:15 PM »
I wanted to make sure I "Preserve Nature", so I put this decal back on.
« Last Edit: October 16, 2023, 06:51:45 PM by SanDogDewey »
Offline SanDogDewey
Re: Dewey’s CB750 K2 - Hondaman Ignition
« Reply #115 on: October 16, 2023, 06:49:36 PM »
Also working to reinstall the Hondaman transitorized Ignition! S/N 098!
« Last Edit: October 16, 2023, 06:52:08 PM by SanDogDewey »
« Reply #116 on: October 16, 2023, 07:06:14 PM »
S/N 098!
Wow! That was a LONG time ago!
Offline SanDogDewey
Re: Dewey’s CB750 K2 - Tool Kit
« Reply #117 on: October 25, 2023, 12:32:14 PM »
Not sure what constitutes a full tool kit, but this is what was in the bike. I know I'm missing the screwdriver handle.
« Last Edit: October 25, 2023, 12:34:03 PM by SanDogDewey »
Offline SanDogDewey
Re: Dewey’s CB750 K2 - Muffler Protector
« Reply #118 on: October 25, 2023, 12:33:29 PM »
Replacing the last of the hex head screws with the correct hardware.
« Last Edit: October 25, 2023, 12:38:21 PM by SanDogDewey »
Offline SanDogDewey
Re: Dewey’s CB750 K2 - Owner's Manual
« Reply #119 on: October 25, 2023, 12:40:16 PM »
Surprised that an original owner's manual is still under the seat!
Offline SanDogDewey
« Reply #120 on: October 25, 2023, 05:44:26 PM »
First start today! Still need to sync carbs and sort out a few small items, but she is lookin' good!
Offline SanDogDewey
« Reply #121 on: October 25, 2023, 05:45:54 PM »
More pics...
Offline newday777
« Reply #122 on: October 25, 2023, 05:47:14 PM »
It is looking good 👍
Stu
My current rides
Prior bikes....
« Reply #123 on: October 25, 2023, 06:19:46 PM »
Gorgeous.
Looking for a second to my nomination for BOTM:  http://forums.sohc4.net/index.php/topic,180400.0.html
