Author Topic: 1975 Honda CB400F,has anyone purchased the replica headlight case from 4into1 ?  (Read 360 times)
Online grcamna2
I was looking for a new headlight case online and noticed 4into1.com has a replica for the oem #61301-369-003B and it looks real good.
The original uses the two separate steel mount sleeves that install into the mounting holes on both sides of the plastic case plus the 2 small steel bushings which also press in to the bottom 2 headlight bulb/rim screw mount holes,which I like.
How does the replica 4into1 plastic headlight case mount-up:is it as good as the original with tight fitting tolerances ?
Does the headlight rim/bulb install tight up top on that tab and operate without vibrating ?
 I had one, it was pretty much like stock. I had it installed and later bought a complete marchal euro headlight from Yamiya. I think I left the 4-1 bucket on the bike and just installed the yamiya/marchal h4/park lamp headlamp into it.
Online grcamna2
Don,did everything fit tight on it ?
I wanted to ask you earlier if you originally purchased the CB400F for your Wife so she could ride ?
