Author Topic: CB550 Hubs and clearcoat  (Read 709 times)
Offline DEklof
« on: January 26, 2022, 03:28:48 PM »
My 1977 CB550F is going togat a fancy set of Excel alloy rims and SS spokes.  In preparation for sending off my hubs, i cleaned them up.  It was a PITA and took hours: degrease, media blast, (plastic beads), and then polish to get bak the gloss on the spoke flanges.  Overall, they look pretty good.
I have two questions:
1) were these items originally clear coated?
2) Should I clear coat them before the new wheels are laced?
Thanks
Offline BenelliSEI
  • 1969 cb750
Re: CB550 Hubs and clearcoat
« Reply #1 on: January 26, 2022, 04:18:54 PM »
I’m just doing the same thing, before building new wheels. On previous projects, I’ve just left them alone, for fear of clear coat yellowing or peeling. I’ll be interested to see what others suggest. Powder coating shops now offer “clear”, so another option?
Offline bistromath
« Reply #2 on: January 26, 2022, 04:26:52 PM »
The single best thing I did on my rebuild was get the cases and wheel hubs vapor-blasted. Give them the occasional WD-40 wipedown and they'll stay pretty forever. Wish I'd done my fork tubes the same way.
'75 CB550F
Offline calj737
  • I refuse...
« Reply #3 on: January 26, 2022, 09:30:12 PM »
A better treatment for aluminum is a product like “Shark Hide”. It is widely used in marine environments for aluminum railings, tuna towers, trailers, etc. A treatment 2x annually should keep your hubs (and motor if left unpainted) looking clean and satin-y.
Offline flatlander
« Reply #4 on: January 26, 2022, 11:09:26 PM »
cal, do you know how shark hide fares under heat, e.g. on engine parts like cylinder head?
Offline calj737
  • I refuse...
« Reply #5 on: January 27, 2022, 06:06:16 AM »
To my knowledge, it does not suffer. A pal uses it on his Harley motor and has never mentioned a problem. I don’t have any unpainted engine cases on my bikes, so I don’t have firsthand experience with that. And all my CB hubs are powder coated. But my marine toys and trailers love it.
Offline flatlander
« Reply #6 on: January 27, 2022, 06:43:36 AM »
great, sounds good.
i have polished alu on hubs and also engine parts. i've used simichrome on them which polishes and also leaves a protective coating. looks good, i apply it once or twice a year and it prevents corrosion as well. but i don't have real long-term experience with it, and have had good results with marine compounds in other applications. they seem to stand up better to atmosphere and weather influences than other stuff so i may give this one a try.
Offline BenelliSEI
  • 1969 cb750
« Reply #7 on: January 27, 2022, 07:08:52 AM »
Sounds good. Will try it too.
« Reply #8 on: January 27, 2022, 07:31:47 AM »
Hey Cal...have never heard of it, but my boat is fiberglass. Sounds like an interesting product...
https://sharkhidestore.com/products/sharkhide-metal-and-aluminum-protectant
Offline calj737
  • I refuse...
« Reply #9 on: January 27, 2022, 10:43:41 AM »
Most boats are gel coat to a degree. But the trailers (especially for saltwater boats) are fully aluminum. Those need lots of care lest they oxidize to nothing after a few years. And of course, tuna towers, cobia towers, etc are typically anodized aluminum and they need love too.
Lots of people do wipe them down with WD-40, but that can create a residue elsewhere on the fishing tackle that is often frowned upon. Lots of ways to skin a cat…
Offline Tim2005
« Reply #10 on: January 27, 2022, 01:48:17 PM »
One issue with clear or powder coating hubs is that that layer gets damaged/worn through at the spots where the spokes are tight against the hub, if it then gets salt or a lot of wet on it then corrosion will get under the coating & is really hard to clean up.
« Reply #11 on: January 27, 2022, 02:34:48 PM »
But the trailers...
When we boat our boat, almost 11 years ago at the Austin boat show, we did not order a trailer. It's stays on the dock all year 'round on a lift.
I had been trailering boats since teen years, tired of trailering!
Offline flatlander
« Reply #12 on: January 27, 2022, 11:01:35 PM »
boat your boat, don't trailer it your boat.
ok, getting my coat  8)
(crap, even coat rhymes with boat. what was in my drink yesterday...)
