Author Topic: Brake Piston Removal Grease Gun Method  (Read 1228 times)
Offline zalion0
« on: January 31, 2022, 01:55:57 AM »
Figured i'd post this as it may help someone in the future. I have a '77 CB750 F2 and like many, needed to remove the brake pistons from the callipers. I had no access to an airgun or a working master cylinder to pump the piston out. In the end, I used a 'Hilka Pro-Craft Manual Grease Gun Set 6 Pieces' which came with all the attachments I needed, so no need for extra purchases. It also included a 3oz grease cartridge which was enough grease to move all pistons. It was also fairly cheap at £17.
https://www.screwfix.com/p/hilka-pro-craft-manual-grease-gun-set-6-pieces/4744r
« Last Edit: January 31, 2022, 06:35:04 AM by zalion0 »
Offline fizzlebottom
Re: Brake Piston Removal Grease Gun Method
« Reply #1 on: February 15, 2022, 07:51:55 PM »
I used this method years ago when I rebuilt the calipers on my 650. Worked like a charm. The only problem is that you then have to clean up all of the nasty grease you shoved inside the caliper.
1982 CB650SC Nighthawk
« Reply #2 on: February 16, 2022, 07:33:13 AM »
+1...last time I did in my garage, the grease hit my fan that was sitting next to my workbench...talk about #$%*e hitting the fan!!!
I find using compressed air more exciting!
Offline krusty
« Reply #3 on: February 16, 2022, 01:20:17 PM »
I too have used this method many times. I had a Suzuki rear brake slave cylinder with seized pistons. The wheel and hub it was in had lain outside in the weather and dirt for many years behind a dealer shop. For months I tried all the coventional methods - air pressure, soaking in various concoctions, heat. etc. It wasn't 'till I discovered the grease gun method that I finally got the pistons out. Easy-peasy. Cleaning out the grease is a two minute job in my shop kero parts washer.
Honda
1976 CB750F1
1978 CB750F2
1972 CB350F
1961 C100 Cub
1962 C100 Cub
1959 C76
1963 C92
1964 C95
Suzuki
1963 M15D 50cc
1961 250TA Colleda
Yamaha
1977 DT175E x 2
1978 DT125E
1979 DT125F
1976 DT250E
1978 DT250G
1984 FJ1100
1990 FJ1200
Online Don R
« Reply #4 on: October 19, 2023, 12:59:36 PM »
 I've used the grease gun on a caliper and a master cylinder this week as well as using a master cylinder that needed flushed to pump the piston out of another caliper. A putty knife, a few paper towels and it's cleaned up.
