Author Topic: 1981 XV1000 TR1-project  (Read 63029 times)
Offline DME
« on: February 05, 2022, 03:58:56 AM »
My current project, 1981 XV1000 TR1.
Started out fairly stock with a luggage rack and a rusted out exhaust.
So far I've made a new stainless exhaust, new subframe, laced up CB750 wheels, stainless battery tray, footrests etc.
Dry weight is down from 220 to 180 kilo as it stands right now, without electrical harness, seatpad and carbs.
The goal was to keep it under 190 kilo and that looks doable.
Right now the plan is to get drivable before this summer and spend next winter on engine rebuild and finish/paint.
Cheers
Dan
« Last Edit: February 08, 2022, 06:53:02 AM by DME »
ken65
Re: XV1000 TR1
« Reply #1 on: February 05, 2022, 04:20:26 AM »
Good job and looks sharp. Looks like you know what you doing.  Will watch with interest.
Re: XV1000 TR1
« Reply #2 on: February 05, 2022, 06:31:54 AM »
And the nice tooling in the shop to do it right. Looks good all slimmed down into kind of a flat tracker look.
Offline DME
Re: XV1000 TR1
« Reply #3 on: February 06, 2022, 03:26:54 AM »
Thanks, here's a couple more pics as it stands right now:
Offline DME
Re: XV1000 TR1
« Reply #4 on: February 06, 2022, 03:30:06 AM »
...and:
ken65
Re: 1981 XV1000 TR1-project
« Reply #5 on: February 08, 2022, 03:38:57 PM »
Sweet. Wish I could do that.
Offline BenelliSEI
  • 1969 cb750
« Reply #6 on: February 08, 2022, 08:47:30 PM »
Watching. Very nice work.
Offline DME
« Reply #7 on: February 12, 2022, 01:38:01 PM »
Converted from 630 to 530 chain using an 18 tooth XS650 front sprocket that needed a oneoff lock washer:
Offline DME
« Reply #8 on: February 12, 2022, 01:45:21 PM »
CB750 rear wheel laced slightly offset for correct alignment with a 34 tooth sprocket made from a blank:
Offline DME
« Reply #9 on: February 12, 2022, 01:58:26 PM »
Will run electronic speedo so speedo drive was ditched and an adaptor to correctly space the Yamaha discs on the Honda hub as well as hold a seal was machined.
Stock discs was drilled.
Offline DME
« Reply #10 on: February 12, 2022, 02:09:16 PM »
Footpeg brackets milled from 10mm aluminium plate. Footpegs retain stock placement, mods done only to reduce weight.
Offline DME
« Reply #11 on: February 12, 2022, 02:17:08 PM »
Made a battery tray out of 16 gauge stainless to hold a lithium battery weighing 0.9 kilo. Stock battery is 7 kilo...
Battery will reside under the swingarm.
Offline DME
« Reply #12 on: February 12, 2022, 02:29:56 PM »
2-1 header made from 18 gauge AISI304 stainless, 1 5/8" stepping up to 2" at the collector:
« Last Edit: February 12, 2022, 02:36:55 PM by DME »
Offline DME
« Reply #13 on: February 12, 2022, 02:31:36 PM »
Offline DME
« Reply #14 on: February 12, 2022, 02:36:16 PM »
Heatshield milled from 16 gauge 2.5" inch pipe. Also 304 stainless which is horrible to machine but it worked.
ken65
« Reply #15 on: February 12, 2022, 02:47:22 PM »
Thanks for the pics. Very interesting.  You are very talented.
Offline Bankerdanny
  • Endeavor to persevere
« Reply #16 on: February 14, 2022, 11:18:56 AM »
10 years ago or so I was tracking an XV920 at a local bike wrecking yard and sales operation. This was before the XV Cafe conversion thing. I still regret not pulling the trigger. I haven't seen another of the chain XV's in 5 or 6 years.
Offline DME
« Reply #17 on: February 24, 2022, 10:40:12 PM »
Seatpad done:
ken65
« Reply #18 on: February 25, 2022, 02:51:44 PM »
Nice work.
Offline Ellz10
  • ZZ
  • Knowledge is Power
« Reply #19 on: February 28, 2022, 02:04:48 PM »
I was thinking quite the same thing. I aspire to be this proficient with a lathe and mill.
Thankful for everyone on this forum. Grateful to continue to learn so much.
'77 K7 - http://forums.sohc4.net/index.php/topic,193043.msg2251436/topicseen.html#new
« Reply #20 on: March 03, 2022, 07:51:44 PM »
  I think it was Billy Joel that had one they made into a Vincent look-alike. I shopped for monoshock Viragos for a while after seeing that one.
Offline DME
« Reply #21 on: March 05, 2022, 01:34:12 AM »
A new pair of Mikuni VM38's fitted and they will replace the stock Hitachi CV40's...
« Last Edit: March 05, 2022, 01:50:16 AM by DME »
Offline DME
« Reply #22 on: March 05, 2022, 01:49:48 AM »
...and the wiring loom was dragged out, weighed, and fitted.
Stock weight is 1,5 kilo but it will probably be a few grams lighter when I'm done with it.
This is not my favourite thing to do, but it the next step and it cant be avoided so...
Offline MauiK3
  • A K3 is saved
  • Old guy
« Reply #23 on: March 05, 2022, 07:09:36 AM »
Impressive work!
1973 CB 750 K3
10/72 build Z1 Kawasaki
« Reply #24 on: March 05, 2022, 09:13:13 PM »
I have a similar scale, and I was impressed with it's accuracy at very low weights: I weighed a 750 kick start lever, and it was within an ounce or so of the weight as measured on a triple-beam scale. ;D
