Author Topic: 1981 XV1000 TR1-project  (Read 64087 times)
Offline BenelliSEI
  • 1969 cb750
Re: 1981 XV1000 TR1-project
« Reply #100 on: February 13, 2024, 05:48:51 AM »
Looks really good!
Offline grcamna2
« Reply #101 on: February 13, 2024, 08:18:03 PM »
The vapor blasting/honing you accomplished makes this rear cylinder shine better than PC or paint  8)
75' CB400F/'bunch o' parts'
Offline DME
« Reply #102 on: February 13, 2024, 10:42:14 PM »
Thanks guys, will hopefully get the time to proceed with the other parts soon  :)
Offline DME
« Reply #103 on: February 18, 2024, 11:36:16 PM »
Cases, rear cylinder and rear head are done  :D
« Last Edit: November 22, 2025, 10:48:58 PM by DME »
Offline grcamna2
« Reply #104 on: February 18, 2024, 11:45:23 PM »
Yes they ARE  8) 8) 8)
Do you own the vapor 'Polishing' machine to do this fine work ? !
Offline DME
« Reply #105 on: February 19, 2024, 02:54:07 AM »
Yes, I built my own setup a couple of years ago.
I believe there is a thread about the build here somewhere...
« Last Edit: February 19, 2024, 05:45:52 PM by DME »
Offline DME
« Reply #106 on: February 19, 2024, 03:04:50 AM »
« Last Edit: February 19, 2024, 04:13:31 PM by DME »
Offline MauiK3
  • A K3 is saved
  • Old guy
« Reply #107 on: February 19, 2024, 06:42:01 AM »
Always impressive what vapor honing produces, looks great.
1973 CB 750 K3
10/72 build Z1 Kawasaki
Offline grcamna2
« Reply #108 on: February 19, 2024, 10:49:26 AM »
Yes it is.
Offline DME
« Reply #109 on: February 25, 2024, 01:23:57 PM »
Second cylinder done  :)
« Last Edit: November 27, 2025, 01:42:54 AM by DME »
Offline grcamna2
« Reply #110 on: February 25, 2024, 08:43:08 PM »
 8) Very nice quality work DME.
Offline BenelliSEI
  • 1969 cb750
« Reply #111 on: February 26, 2024, 02:44:29 PM »
This project really appeals to me! Nice work.
Offline DME
« Reply #112 on: March 03, 2024, 09:17:18 AM »
Front head done:
« Last Edit: November 27, 2025, 01:45:45 AM by DME »
Offline DME
« Reply #113 on: March 26, 2024, 03:17:40 AM »
Every single steel fastener (except front and rear axles) for the complete engine and chassis has now been cleaned up and is ready to be sent out for zincplating  :)
« Last Edit: November 27, 2025, 01:48:17 AM by DME »
Offline grcamna2
« Reply #114 on: March 26, 2024, 11:47:45 AM »
They will look good  ;)
Offline DME
« Reply #115 on: April 08, 2024, 11:27:07 PM »
Reassembly has begun and the frozen crank and its bearing slipped into the heated block just by the help of gravity with a nice click.
Now waiting for the replated bolts and steel parts to arrive.
« Last Edit: November 27, 2025, 01:53:10 AM by DME »
Offline grcamna2
« Reply #116 on: April 09, 2024, 12:37:54 AM »
The crankshaft looks Cold !  :)
Offline DME
« Reply #117 on: April 09, 2024, 12:45:59 AM »
-19°C to be exact  ;)
Offline BenelliSEI
  • 1969 cb750
« Reply #118 on: April 09, 2024, 06:23:20 AM »
Following. Very cool project!
Offline DME
« Reply #119 on: April 29, 2024, 07:07:20 AM »
Couldn´t just sit around waiting for the replated steel parts to arrive so I decided to give the alternator cover some needed attention this past weekend.
Got rid of some protrusions that wasn´t needed anymore in the mill, and gave the cover a workover in the cabinet.
The replated parts are destined to arrive tomorrow, but we´ll see...  :)
« Last Edit: November 27, 2025, 01:59:37 AM by DME »
Offline grcamna2
« Reply #120 on: April 29, 2024, 09:49:57 AM »
Your work on the machines has given the cast surface a much smoother finish;I hope the cover will also be smooth where it tightens down on it.
Offline DME
« Reply #121 on: May 01, 2024, 02:25:14 AM »
The replated stuff arrived yesterday as planned, turned out well  :)
Before and after:
« Last Edit: November 27, 2025, 02:04:16 AM by DME »
Offline MauiK3
  • A K3 is saved
  • Old guy
« Reply #122 on: May 01, 2024, 07:56:32 AM »
Nice stuff!
1973 CB 750 K3
Offline grcamna2
« Reply #123 on: May 01, 2024, 08:32:25 AM »
I like those plated small parts;much better than NOS.  8)
« Reply #124 on: May 01, 2024, 11:02:00 PM »
Curious,they charge you by the pound or item,looks like they did a great job platimg that stuff. Is it getting really expensive to do like every thing else these days? How much did the rocker shafts grow by plating?
David
