Author Topic: No wiring harness amongst other things - where to start?  (Read 1400 times)
Offline randomguy81
« on: February 07, 2022, 06:10:11 PM »
Hi all
I have in my garage a 81 CB650 that came missing a wiring harness amongst other things..
I've just refinished building the carbs, fixing the hack chop job on the rear and some other mechanical items and so now I'm moving onto the wiring and I'm now wondering just what I got my naive self into...
I have an M-Unit Blue sitting here and I'm trying to ensure I have all the essentials on the bike to make this wiring happen - today (day 1 of electrical) I realized that the bike does not have a CDI anywhere that I can see and I'm guessing it should be pretty visible (no seat, frame chopped at back and now a hoop after some surgery to it so nothing left wiring wise where I suspect it would have been.
I'm wondering if I am missing anything else (critical) to get this wiring going
So far I have
Ignition
Starter Solenoid + Fuse
Coils
Missing
CDI - I see Ricks motorsport offers one for 130, do I need 2 of these? Thats going to hurt
Connector set - is this even something I can get so I can connect up to the existing plastic connectors or should I just cut and replace?
Would appreciate any help / pointers so I can get this side of things moving
Thank you
« Last Edit: February 07, 2022, 06:53:57 PM by randomguy81 »
Offline calj737
  • Moderator
  • I refuse...
Re: No wiring harness amongst other things - where to start?
« Reply #1 on: February 07, 2022, 08:54:37 PM »
Yes, you need two coils, but only 1 CDI.
https://www.cmsnl.com/honda-cb650c-1981-b_model50286/partslist/0272.html#.YgH2fS08KhA
The 650 uses a “pulse generator” as the ignition, right side of motor, behind the round dish in front of your feet.
https://www.cmsnl.com/honda-cb650c-1981-b_model50286/partslist/0048.html#.YgH27i08KhA
These links are for information purposes, you can order stock parts domestically.
Blending an mUnit into the stock harness is a pain in the butt, especially if electrical is not your forte. You can “cut and replace” the connectors because you’ll be modifying the harness quite a bit.
Offline randomguy81
« Reply #2 on: February 08, 2022, 06:45:46 AM »
Well first off
Thank you - I appreciate the response and help I really do
Pulse generator is present and correct.
Good news on only needing the one CDI then :) I will get one ordered
I've got no issues cutting wires and replacing connectors - used to own a sailboat back in the day and spent a lot of time re-doing original electrical wiring, just want to make sure I wire it up correctly.
I will order a CDI and a pack of waterproof connectors from amazon.
Its been a pain in the butt since purchase but its starting to take shape in the garage and thats a pretty great thing to see.
Offline scunny
  • don't call me expert
« Reply #3 on: February 08, 2022, 12:32:15 PM »
I think you will find the need for 2 cdi units. one for 1&4. the other for 2&3
present-CB 650 retro
            VTR1000F3
           XL250S riverbed rocket
           TS250[sold]
           TS185[sold]
           XL125S[sold]
           MT50 (white)
           MT50 (red)[sold]
           KN250/XS400 project
           SL100[sold]
           XL250R
           pedal(pub bike) leaks oil
Offline randomguy81
« Reply #4 on: February 13, 2022, 01:53:30 PM »
Ah crap
Just as the single CDI turned up
Offline randomguy81
« Reply #5 on: February 20, 2022, 05:28:54 PM »
Ok I now have 2 CDI units and I am looking at the attached wiring diagram from a 750 build
I am particularly interested in the CDI wiring
Just want to make sure this looks good to people here with the knowledge on the M-Unit wiring with CDI's involved.
Thank you
Offline randomguy81
« Reply #6 on: February 23, 2022, 05:41:35 PM »
Anyone?
