Author Topic: What’s the Very Best cb750 Gasket Set?  (Read 1181 times)
Offline BenelliSEI
  • 1969 cb750
« on: February 08, 2022, 08:38:38 PM »
I’m getting ready to work on a very early cb750 engine (#581). I had it running well a few months ago, after sitting dormant for +40 years. No chain noises, smoke or surprises. Shows 17,000 miles on the speedo and I believe that to be correct. It does have a minor head gasket leak, and a few bent fins of the RHS. I plan to do only the top end.
What gasket sets have you used and consider the best? Did you need to retorque the head gasket after first use? Athena top end kits available locally, and I like the look of sets listed by Cyclex. What do you recommend? Thanks!
« Last Edit: February 08, 2022, 08:41:22 PM by BenelliSEI »
Offline jaytee-nz
Re: What’s the Very Best cb750 Gasket Set?
« Reply #1 on: February 09, 2022, 12:17:19 AM »
I've used the Yamiya head gaskets several times and never had a problem (Japanese quality).
They also state that the gaskets are the thickness of the original Honda ones so shouldn't have the o ring issue many others have. Never had to re-torque the head also.
I believe Athena also have a good reputation (seem to recall that Hondaman uses them so that's a recommendation).
« Reply #2 on: February 09, 2022, 05:22:59 AM »
 Be nice if it was just the rubber pucks that were causing the leak and you didn't have to remove the head and cylinders and take it down that far.
Offline BenelliSEI
  • 1969 cb750
« Reply #3 on: February 09, 2022, 05:41:10 AM »
The engine S up in the stand and getting a really good scrape and clean up. Will be checking carefully. There is a lot of muck in a couple of spots. I suspect more than the pucks. We’ll see.
« Reply #4 on: February 09, 2022, 05:58:32 AM »
 With your mechanical ability and the engine all set up probably a good idea to go for a one and done. My hand would probably be shaking a bit working on a Sandie bike with that low of a number.  :D  Hopefully no special head gasket or such for one that early.
« Last Edit: February 09, 2022, 07:58:51 PM by ekpent »
Offline MauiK3
  • A K3 is saved
  • Old guy
« Reply #5 on: February 09, 2022, 07:05:18 AM »
I used Yamiya gaskets. I rechecked torque the next day just to be sure.
#581 is sure low, keep us posted.
1973 CB 750 K3
10/72 build Z1 Kawasaki
Offline 71 V12
« Reply #6 on: February 09, 2022, 08:23:44 AM »
I would recommend opening the sump as well whilst the engine is out. Found a little house of horror lurking in my K0, primary tensioner and cam chain rubber parts were all breaking up. You can see the bits on the oil pump mesh, loads more in the sump pan.
Engine sounded great before pulling it, and was oil tight. The only work I intended to do was give a clean and paint. Ended up with a full rebuild and so glad I did.
For what it worth I used genuine Honda gaskets and seals.
Offline BenelliSEI
  • 1969 cb750
« Reply #7 on: February 09, 2022, 08:29:04 AM »
Excellent advice. I will definitely be going in there and I happen to have an NOS primary tensioner in my spares......
« Last Edit: February 09, 2022, 08:36:55 AM by BenelliSEI »
« Reply #8 on: February 09, 2022, 11:10:35 AM »
I also like the Yamiya's gaskets. Good fitment and cover gaskets like Honda.
Many other gasket sets has bad fitting with holes not lining up and a rough paper like surface.
Not the waxed feeling as Yamiya (blue) and Honda (light green)
Measure the primary chain slack when oil pan is off. Probably not much more than new chains 65mm. Low milage. (Service limit 70mm)
It would be fine if the rubber tensioners could be replaced without tearing everything apart, primary as cam chain.
I found more rubber from tensioners in oil pan when I opened my K6 2010.
Last time tensioners were replaced was 1984.
« Last Edit: February 09, 2022, 11:13:38 AM by PeWe »
Offline Remcod
« Reply #9 on: February 09, 2022, 11:42:00 AM »
If you use the cyclex ones, remember to shorten the breather cover bolts. They are too long because the gaskets are a lot thinner and will snap if you think you can force them down because you didn't realise this. Don't ask how I know this.
Verstuurd vanaf mijn SM-A415F met Tapatalk
Offline Shtonecb500
    • Youtube profile
« Reply #10 on: February 09, 2022, 12:57:26 PM »
Vesrah is used in our shop.
73/74'' CB500/550 resto-mod - sold
75' 750f 91' cbr f2 swap cafe - mock up
74' 750 chopper hardtail - complete - sold
74' CB750/836kit - Black mix & match - daily rider - always tweaking
71' cb500 K0 survivor - complete
71' K1 - CANDY GOLD/BROWN Winton kit - in process
Offline flybackwards
« Reply #11 on: February 09, 2022, 02:29:49 PM »
I used the Cyclex dual layer steel head gasket and their other gaskets on my K7 rebuild - all tight for oil but it looks like the head gasket needs to be re-torqued - I started to get a few seconds of oil smoke on startup from #1 after I did a hot run on 401 for a couple of exits. Most likely I was light on the torque at assembly. All the Cyclex gaskets look like good quality.
Offline atm cycles
« Reply #12 on: February 09, 2022, 04:17:20 PM »
Be mindful that a couple gaskets are unique to Sandcast only. Oil pan and clutch cover. The head gasket is also different from early diecast back. I suggest using a nos with the copper rings. As recommended by MRieck
« Last Edit: February 10, 2022, 03:07:47 AM by atm cycles »
Offline BenelliSEI
  • 1969 cb750
« Reply #13 on: February 09, 2022, 05:27:24 PM »
Tons of excellent advice. Much appreciated!
