Author Topic: a cable lube tool ?  (Read 1002 times)
Online grcamna2
a cable lube tool ?
« on: February 10, 2022, 06:20:43 PM »
I had a single thumb screw cable lube tool made by Motion Pro back in the 90's and used that all the time;don't know what happened to it,loaned it out?  ::)
I purchased a Motion Pro double thumb screw cable lube tool and it leaks All The Time and won't allow the lubricant to enter the cables at all:what a pain.I know Motion Pro makes the new small 2-piece cup tool and it doesn't excite me much:I'm used to my old style standard clamp-on type.
What have you members experienced with cable lube tools,the ones which use an aerosol can ?
Offline Alan F.
Re: a cable lube tool ?
« Reply #1 on: February 10, 2022, 06:40:33 PM »
They all leak a little, I like to keep the cable moving to help speed the process.
Online grcamna2
« Reply #2 on: February 10, 2022, 06:51:33 PM »
Which brand/type do you use Alan ?
Offline goodtryer
« Reply #3 on: February 10, 2022, 06:53:36 PM »
I have the new version Motion Pro. It works but it's somewhat messy. There's a void inside it where the cable end is trapped. You push the lube spray straw into the hole in the rubber piece of the Motion Pro and spray. Some of the lube goes into the cable. Some of it waits for you to unscrew the contraption so it can spill on your hands and the floor.
It works ok. Neither great nor terrible.
Cheers
"Tolerance will reach such a level that intelligent people will be banned from thinking so as not to offend the imbeciles."
-Dostoievski
1977 CB550K
1978 CB750K
1973 CB500K
Offline Alan F.
« Reply #4 on: February 10, 2022, 07:12:37 PM »
I've got two to increase my chances of finding one when I need it, I'll probably have a third one someday.
I think the first is Motion Pro, the other is the same style but a different color. They're all Chinesium.
ken65
« Reply #5 on: February 10, 2022, 08:08:14 PM »
I've got an old motion pro single screw one. If I get it in the sweet spot it doesn't leak at all.
But sometimes finding a G spot would be easier. :D
Online grcamna2
« Reply #6 on: February 10, 2022, 08:30:05 PM »
Lol  :D
« Reply #7 on: February 11, 2022, 12:44:26 AM »
Some cables do not need lube, right?
Online dave500
« Reply #8 on: February 11, 2022, 12:46:53 AM »
i have a single screw ive had forever,i think they all leak a little but the point is they do help direct the lube into the sleeve,youll never get a perfect seal i think?
Offline Kelly E
  • Geriatric Hooligan
« Reply #9 on: February 11, 2022, 06:00:43 AM »
Our two screw tool worked great for a while but now it leaks. To be honest we've used it a lot so maybe we wore it out. 8)
1978 Kawasaki KL 250
1980 Suzuki GS 1100E
1983 Honda CB 1100F
1984 Honda VF 700S Sabre
1990 Moto Guzzi 1000 Le Mans
2005 Harley Davidson Fat Boy
Offline bear
  • Leeton in Australia
« Reply #10 on: February 11, 2022, 11:23:11 PM »
Suggestion.............
I use a made up unit.
3 or 4 inches of fuel hose or the like with an air line snap fitting attached to one end. Push the other end onto your cable. Turn your compressors gauge down low. Fill the fuel line with lube and snap it onto the airline.
Bob's your uncle!  ;)
« Last Edit: February 11, 2022, 11:27:08 PM by bear »
Online grcamna2
« Reply #11 on: February 12, 2022, 02:30:17 PM »
I Like that:hose over the outside of the cable.I can make one !
