Author Topic: 1978 PD46c Carbs... the Step child of the 550 Carbs  (Read 623 times)
Offline DJBlackRabbit
« on: February 14, 2022, 05:14:21 PM »
This week I have begun attempting to clean these grimy carbs. The spring in the middle, where can I get a replacement? It looks like its toast.
Thanks in advance!
[url=http://[url=https://flic.kr/p/2n3AsQD]]
Re: 1978 PD46c Carbs... the Step child of the 550 Carbs
« Reply #1 on: February 14, 2022, 06:53:48 PM »
It just looks mis-installed by a turn? it is a gentle spring, but if wound an extra turn it looks much like that one. Maybe pull it off of its perches and see if the shape recovers to a coil. Its purpose is to try to close the choke plates' shaft, and the 'unset' choke position of the cable pushes the choke shaft open.
« Reply #2 on: February 14, 2022, 07:14:15 PM »
Will give that a go, thanks!
« Reply #3 on: February 14, 2022, 08:21:05 PM »
Only place is another set of carbs, i threw 3 sets out last august, never gona touch another set!
« Reply #4 on: February 14, 2022, 10:34:14 PM »
i hate em!
« Reply #5 on: February 14, 2022, 10:43:50 PM »
i hate em!
Im new, but quickly learning the hate lmao
« Reply #6 on: February 15, 2022, 12:31:45 AM »
have you got the complete stock airbox system?or has it had pods fitted?
Offline Deltarider
« Reply #7 on: February 15, 2022, 03:17:09 AM »
Although the language is French, you may find useful info here: http://www.cb500four.com/fofo_cb500four/viewtopic.php?f=16&t=623 I mean the pics are good.
CB500K2-ED Excel black
« Reply #8 on: February 15, 2022, 05:42:47 AM »
Bike came with the carbs in pieces in a box (not the best of signs lol). No air filter parts besides the plastic piece that sits between the carbs and the air filter assembly. I was thinking about running pods once i get the bike running only because those filter parts look like they are pretty difficult/expensive  to find.
« Reply #9 on: February 15, 2022, 05:49:48 AM »
Thanks ill add this to my carb data base. You can never have too much info on these things and pics!
« Reply #10 on: February 15, 2022, 11:38:45 AM »
if you can get the rest of the factory filter system it WILL run a lot better,with pods you have to trial and error the jetting,and even after that it still wont be as good as stock,pods are easy to fit and look the cafe racer part and thats about it.
« Reply #11 on: February 15, 2022, 04:43:24 PM »
If you can't find the rest of the factory airbox stuff, maye try this: get a single pod, make a short piece of pipe (PVC, aluminum, whatever) to mount inside that carb plenum and into the air filter, and then block off the lower 1/2 to 3/4 of the pod, letting it 'breathe' from under the seat. This will actually work, and will run quite well.
« Reply #12 on: February 15, 2022, 04:47:20 PM »
Interesting! will try
Offline commander60
« Reply #13 on: February 15, 2022, 05:13:08 PM »
Perhaps a picture or sketch on that pod mod, Honda man, thanks
