Author Topic: How F'd am I? (Broken Clutch cover bolt)  (Read 1038 times)
Offline DJBlackRabbit
« on: February 19, 2022, 06:01:59 PM »
I have one bolt left to take off my clutch cover on my cb550 and it wouldnt come off (bad angle with tools i had). I tried a manual impact, my JIS drivers, a powered impact , cutting a slot with a Dremel then powered impact again, then I tried drilling it out with a reverse bit all to no avail. The hole drilled is off center (my dumbass fault) and it looks hopeless. Any thoughts on getting this cover off?
Offline exponent
  • Obsessed
Re: How F'd am I? (Broken Clutch cover bolt)
« Reply #1 on: February 19, 2022, 06:38:14 PM »
Deep breath
Drill again
Deep breath
Heat with torch
pb blaster
Extractor
'78 550K 2106630
Offline Alan F.
« Reply #2 on: February 19, 2022, 06:43:47 PM »
Drill the head off as best you can and try not to damage the cover. If you damage the cover patch with JB Weld, at least it's at the top where it won't leak much. Check often while drilling so you don't go too far.
Don't worry, you're not the first and won't be the last.
Online scottly
« Reply #3 on: February 19, 2022, 06:50:04 PM »
That's not bad, just switch to a 1/4" drill bit, and drill the head of the screw off. Pull the cover off over the stub, and use vise grips to unscrew it. When drilling, try to redirect the point of the bit to the center of the screw shank, then push the bit straight in, if that makes sense..
Offline Alan F.
« Reply #4 on: February 19, 2022, 07:37:26 PM »
Also be aware that the stump of the remaining screw will have sharp edges.
Online Don R
« Reply #5 on: February 19, 2022, 08:34:35 PM »
 What Scottly said. It works.
Offline DaveBarbier
« Reply #6 on: February 19, 2022, 11:03:41 PM »
+1 to scottly
Not a problem yet. Get the cover off and deal with the remaining stud. Heat (propane) and vise grips.
« Reply #7 on: February 19, 2022, 11:05:19 PM »
with a sharp chisel or pin punch you should be able to knock that in the undo direction with care,ive done plenty of the same,at least give it a shot,once its nudged itll come out with vice grips if you can get a decent grab on it,also try hitting it straight in with a straight square punch,might shake up the stubbon threads?
Offline Kelly E
  • Geriatric Hooligan
« Reply #8 on: February 19, 2022, 11:10:13 PM »
Most of the time once you drill off the head and remove the cover the shank of the bolt will probably unscrew by hand.
1978 Kawasaki KL 250
1980 Suzuki GS 1100E
1983 Honda CB 1100F
1984 Honda VF 700S Sabre
1990 Moto Guzzi 1000 Le Mans
2005 Harley Davidson Fat Boy
« Reply #9 on: February 19, 2022, 11:33:52 PM »
funny how old jap road bikes had those JIS heads but the dirt bikes got allens?
Offline 2wheels
« Reply #10 on: February 20, 2022, 06:47:08 AM »
I like Scotty's way.
Once the case is off and the vise grips are on.  Be very very careful.  Remember you have hours to get the screw out,  No Hurry.
Back and forth, back and forth on that screw.  Do NOT rush.  Add lots of penetrating oil.
Propane torch heat is very helpful.
The threads of the screw are probably full of that nasty white corrosion.  It will wash out with the back and forth action.
1970 CB750 K0 (I can't believe I tossed my duck tail seat in the trash 30 years ago)
« Reply #11 on: February 20, 2022, 07:55:32 AM »
A lot of good info here guys! Thank you will try again today
Offline MrGardman
  • Northern Indiana
« Reply #12 on: February 20, 2022, 04:20:38 PM »
I remember removing the head and cylinder studs from 750s. Some were terrible to get out. A little heat will do wonders for that white corrosion.
Offline Gurp
  • I'm no.......
  • Once was a...
« Reply #13 on: February 20, 2022, 10:16:49 PM »
My first move would be slot it deeply with a dremel then use a hand impact driver and a good hammer. taken many out that way.
slow Progress 74 cb550.
Poor boy chop 73 CB500 chop
Future project 77 Cb750 Amen Savior
Offline Ellz10
  • ZZ
  • Knowledge is Power
« Reply #14 on: February 21, 2022, 09:26:24 AM »
Slot it, torch it 1-3 mins, cold chisel. Rinse & repeat.
I've been there so many times before and I'm sure many more times to come.
You'll figure it out.
Thankful for everyone on this forum. Grateful to continue to learn so much.
'77 K7 - http://forums.sohc4.net/index.php/topic,193043.msg2251436/topicseen.html#new
Offline desertrefugee
  • Still wanna be a...
  • Phoenix, AZ
« Reply #15 on: February 21, 2022, 09:51:23 AM »
... and nothing [NOTHING!] is more satisfying than that "pop" when a stuck screw releases and comes free!
'86 Vmax, '83 ZN1300, '78 GL1000, '75 CB750 K5, '78 F4
Offline jgger
« Reply #16 on: February 22, 2022, 08:11:42 PM »
A trick I learned a long time ago, before you get to the "drill phase" of oh crap screw removal. On the boogered head use a flat punch to peen the boogers part back into the screw,just a little more than making the screwdriver fit. Then use the bit from your impact driver and tap it into the hole for a good tight fit. Then use the impact driver with a larger than normal hammer for that one last hail Mary whack, don't be shy. This works about 90% of the time and has saved my butt more times than I  care to remember. If it fails you still have the drill.
  • Phoenix, AZ
« Reply #17 on: February 23, 2022, 05:48:36 AM »
Hmm.  I have honestly never tried that, but I could see where it might work. Noted and filed away. Thanks!  Never too late to teach an old dog new tricks.
Offline Bankerdanny
  • Endeavor to persevere
« Reply #18 on: February 23, 2022, 07:55:21 AM »
I had to do this with 3 screws on my valve cover, it works like a charm.
Offline craz1
  • CDA, Idaho
« Reply #19 on: February 23, 2022, 11:40:21 AM »
If the head is exposed and you can get a vise grip on the side of it and twist it, that normally works. Otherwise drill the cap off and deal with the stud.
74 CB550,73 Z1900, 74 Z1900, 75 Z1900,
72 XS2650, 73 RD350, 2013 FJR1300, 84 XJ550 YAM
« Reply #20 on: February 23, 2022, 03:48:52 PM »
Deep breath
Drill again
Deep breath
Heat with torch
pb blaster
Extractor
def needed to breathe lol! Thanks everyone for the advice! Cutting the head off and smacking/pulling the cover eventually worked. Had the same issue with the stator cover and used the same method!!! Grateful
Offline Kevnz
« Reply #21 on: February 23, 2022, 05:42:09 PM »
Good news. Hopefully plain sailing from here.
Good grammar: The difference between knowing your #$%* and knowing you're #$%*
« Reply #22 on: February 24, 2022, 01:03:01 AM »
even with a good impact driver and correct JIS bit you should dig the cross slots out with a scriber or similar,then with compressed air blow them out,then insert just the bit only and hit it with a decent hammer to hopefully loosen the threads,then use the impact driver,lotta those screws aint been out since the factory install!
