Author Topic: Hydraulic oil thread lol.  (Read 1017 times)
Online Don R
« on: February 21, 2022, 07:19:42 PM »
 I made my own pipe and tube bender and powered it with an air over hydraulic pump. It's made for a hoist or jack, so I leave a hundred pounds of air on the return side of the cylinder and when I step on the "let it down pedal" it works like a load or spring to return the cylinder and push the oil back to the reservoir.
 Today I noticed the cylinder squeal a little so in the absence of proper hydraulic oil I used a few drips of snap on air tool oil in the air side. Bad idea, the rubber o ring in there grabbed the inside of the tube and refused to let go. Then I tried 10W belray fork oil, seemed legit. Stuck it hard.
  I had to take it apart, clean it and lube the piston seal with some of the hydraulic oil from the pump and wet side of the cylinder, I spilled it everywhere and used a little 20W50 on a rag to wipe the bore of the cylinder with.
  My lead hammer got a workout getting it apart without dinging anything but now the piston slides back and forth again.
   Moral of the story, if you don't have the right fluids, go get them.
« Last Edit: February 21, 2022, 07:22:48 PM by Don R »
Re: Hydraulic oil thread lol.
« Reply #1 on: February 21, 2022, 08:08:41 PM »
This should be on the pissed off thread, Don. ;D
Offline BomberMann650
  • Holy Cow! I'm a
  • Dr. Bovinestein iBa#80333
« Reply #2 on: February 21, 2022, 08:43:26 PM »
I've heard it works better if you spit on it.
Online Don R
« Reply #3 on: February 21, 2022, 09:26:42 PM »
  That's a fact. Now my buddy can come back and finish bending the funnycar and Jr, dragster cage parts. He has another nostalgia funnycar next month, it needs halo bars and a "kickstand" update to the front hoop.
« Reply #4 on: February 22, 2022, 04:50:13 AM »
Interesting.  I was fixĂ­ng my trailer mounted crane and used Mobil Delvac as hydraulic fluid in it.  Never had a problem but maybe HF hydraulics are not that precise.
Online Don R
« Reply #5 on: February 24, 2022, 02:46:25 AM »
 Still working smooth today, it liked the 20W50 wipedown on the o ring and cylinder. It returns as low as 40 psi now.
